New tacoma needs lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by caseychai, Mar 12, 2013.
  1. Mar 12, 2013 at 1:36 AM
    caseychai
    caseychai [OP] Well-Known Member
    casey
    oahu
    2010 tacoma 4x4
    Hey everyone, just got a 2010 tacoma 4x4 access cab.
    want to put a 3" leveling kit and some 32x11.5 BGF all terrains.
    i was wondering what would look good and function properly.
    i was gonna go with the ready lift 3" front 1" rear blocks.
    I wanted to also put a wheel spacer, I like the wider tire look so I wanted to go with the 1.5 inch, even though most recommend the 1.25 inch.
    would the 1.5 inch stick out too far? i dont want any problems when getting safety checks. my last tacoma could never pass inspection because the tires stuck out a tad bit too far.
    -thanks
  2. Mar 12, 2013 at 1:39 AM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    Dont do ready lift or blocks. If money is an issue do 5100s with toytec 3" springs and an AAL in the back. Blocks are junk. 1.5 spacing might cause alignment issues from what i can remember reading up on.
  3. Mar 12, 2013 at 2:05 AM
    caseychai
    casey
    oahu
    2010 tacoma 4x4
  4. Mar 12, 2013 at 2:33 AM
    ToyComa92
    Jon
    Conifer, Colorado
    Yah those are the exact ones i have and i like them of course they arent like the icons or kings but for good lift good ride and good quality this is the best choice.
    For rear lift id suggest either an AAL or if you have alot of miles on your truck id look at saving up for some Dakars. Look at your leaf sets in the rear and if they are 3 leafs and 1 overload leaf then you need the TSB which ToyTec would be more then happy to set you up with what you need. All in all with the new 5100's and rear add a leaf you should see 3" of lift. I saw around 3.5 because of how shot my shocks and leafs were.
    If your leafs are neg arching then i would just recommend full Dakars.
  5. Mar 12, 2013 at 2:47 AM
    caseychai
    casey
    oahu
    2010 tacoma 4x4
    Awesome!
    also, how much does a mechanic usually charge to install all of this? im living away from home right now, and dont have a garage or the necessary tools in my situation.
  6. Mar 12, 2013 at 3:35 AM
    ToyComa92
    Jon
    Conifer, Colorado
    Um... its kind of hard to get a good price range but at normal shop rate of 90 an hour id say... 2 hours for rear and 1 and a half maybe 1 hour for each wheel up front so around 4-5 hours of work. would be a good deal. I personally wouldn't pay over 500, but then again im a apprentice mechanic so i dont pay anyone lol they pay me.
  7. Mar 13, 2013 at 12:05 AM
    caseychai
    casey
    oahu
    2010 tacoma 4x4
    if I go with this kit (because its half the price), do I need to buy coils?
    http://www.toyteclifts.com/index.ph...tegory_id=113&option=com_virtuemart&Itemid=72
    because this kit comes with the coils, but i dont want to spend this much.
    i guess what im asking is, if i get the bilstiens 5100 do i need to buy new coils? or can i use the coils from my stock shocks?
    I want to make sure the kit has everything i need, if not what else would I have to buy?
  8. Mar 13, 2013 at 12:06 AM
    caseychai
    casey
    oahu
    2010 tacoma 4x4
    and what exactly do the new coils do?
  9. Mar 13, 2013 at 6:34 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    None!
    You can use your stock coils with the 5100's. They will be compressed so the ride is going to be a little rougher.
