New Tacoma new build questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bizz, Feb 17, 2020.
  1. Feb 17, 2020 at 6:13 PM
    Bizz
    Bizz [OP] Well-Known Member
    Craig
    Dallas, GA
    2020 TRD Sport DCSB Cement Grey
    Too many to list. I’m lazy
    So... I’ve done A LOT of research and still can’t seem to find the answer to my question. any help would be appreciated.
    I previously had a 18 TRD Sport that I unfortunately totaled (not my fault, I have dash cam footage of rolling at 75 mph if you wanna see it) and I installed a 3 in spacer lift and a wheel and tire set up as follows: wheels were 20x10 -12 wrapped in 33 x 12.5 Toyo OCRT’s and has a slight rub at full lock reverse.
    I now have a new 2020 trd sport and I want to do it right this time. I’ve ordered a King 3” coil over kit with the leaf pack and remote res but I don’t want the same wheels. I am looking at the VenomRex 602’s. They are offered in a 17 x 9 and a 20 x 9. The 17’s have an offset of -12 and the 20’s -18. See where I’m going yet?
    My main question is, if I go with the 20’s with the larger offset which changes my BS from 5 to about 4.5 and run the same size tire as before will I have MORE of a clearance issue than I did? Minor rubbing doesn’t bother me and I don’t mind trimming like I did last time but I really want to keep the aggressive stance I had before but don’t want to get in over my head with cutting stuff to accommodate. Maybe go with a 12 or 11.5 to be safe?
  2. Feb 17, 2020 at 6:21 PM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Not sure if this helps, but i’ve been told for my 3” spacer lift the biggest tire i could place on it with the factory off-road wheels, and get no rubbing off highway was 285/75r16
    Bizz[OP] likes this.
  3. Feb 17, 2020 at 6:28 PM
    Bizz
    Craig
    Dallas, GA
    Yea that’s a bit smaller than I had before but I’m just getting stuck on the offset thing. I’m thinking I should go thinner on the tire?
