New Tacoma Owner. Do's and Don’ts when owning brand new Tacoma??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaCawd2007, Aug 25, 2021.
  1. Aug 27, 2021 at 10:45 AM
    #81
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I get the crappy fuel bit, but we have good fuel here, its not the problem. These trucks do not all run exactly the same from what i see here. Many run like they should, but some are down in power, or have strange vibrations issues going on. Seems the good ones all get roughly the same fuel mileage while these others when driven the same way don't.
  2. Sep 6, 2021 at 1:16 PM
    #82
    afgixxer
    afgixxer Well-Known Member
    Tennessee
    2021 Tacoma TRD-Off Road (Cement)
    Do you have any photos of your diode? Which bulbs did you get?
  3. Sep 6, 2021 at 1:37 PM
    #83
    Rainman443
    Rainman443 Well-Known Member
    A Big Island
    2021 TRD OR
    Don't get a bed mat if you like to slide things in and out of your bed
  4. Sep 6, 2021 at 4:34 PM
    #84
    andagi808
    andagi808 Well-Known Member
    Hawaii
    2021 Black Tacoma TRD OR MT
  5. Sep 6, 2021 at 5:00 PM
    #85
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    White Oakleys brah
    vivid02[QUOTED] likes this.
  6. Sep 6, 2021 at 5:09 PM
    #86
    Clearwater Bill
    Billy
    Largo Florida
    Read the owners manual
    Use it as is, change something when something doesn't work as you wish.
    Use caution when visiting Lemming-ville or you'll find yourself with a 'leveling kit', black wheels, tires of a size, tread pattern and compound you dont need just for looks.
    davidstacoma likes this.
  7. Sep 6, 2021 at 5:20 PM
    #87
    jimp
    jimp Well-Known Member
    Tampa
    21 TRD Sport
    none
    Don't complain about heavy steering and brakes.
  8. Sep 6, 2021 at 5:27 PM
    #88
    mattsolnitzky
    mattsolnitzky Well-Known Member
    2021 TRD Sport
    Swap out the interior lights for some LEDs. Brand isn’t all that important, nearly anything is better than stock. Inexpensive, and a Big Bang for your buck.
  9. Sep 6, 2021 at 5:28 PM
    #89
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Those bigger flares make it look like a real truck imo. Factory are too skinny.
  10. Sep 6, 2021 at 5:38 PM
    #90
    rdvm1972
    rdvm1972 Well-Known Member
    Richard
    2020 Black Tacoma SR5 4x4
    None, brand new. Looking for ideas
    Too true…
  11. Sep 6, 2021 at 5:42 PM
    #91
    SRick
    SRick Well-Known Member
    Rick
    2017 White Tacoma SR Access Cab Utility 4x4, 4 Cyl/5 SpdMT
    - ECGS Front 4x4 Needle Bearing Replacement Bushing - RCI Tacoma Skid Plate - Cooper, Discoverer AT3 4S, 265 /75 R16 116T SL OWL - 16" Dark Anthracite Alloy Wheel, PT94635160 - A/C Condenser Hose reroute - OEM all weather mats / OEM door sill protectors (stock) - Installed Intermittent Windshield Wiper Switch Assembly - Installed Towing rear light kit-4 wire - Installed Draw-Tite Max-Frame Trailer Hitch Receiver - Custom Fit - Class III - Installed CLAZZIO Leather Seat Covers, Gray - RCI Tacoma Gas Tank Skid Plate (on order) - RCI Tacoma Rock Sliders Rock Sliders
    Do's:
    Change all fluids at 5-10k
    Seat covers (Clazzio's are great)
    Bed Mat
    LED Interior Lighting
    AC Drain Mod
    Rear Diff Vent Mod (amazing Toyota hasn't addressed this)
    Look at some of the other useful mods in the forum
    Seat Belt Extender Pros, Toyota Tacoma Seat Belt Extender Rigid - if you put stuff in your front seat- keeps the alarm from going off and annoying alarm--- great $20.00 purchase
    Don'ts:
    Not do regular maintenance (these trucks will last forever, if you keep up on the maintenance)
  12. Sep 6, 2021 at 6:02 PM
    #92
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    Do buy spoil your wife with lots of random flowers and gifts since she will be jealous of all the $$$ being spent on your Tacoma.
  13. Sep 6, 2021 at 6:07 PM
    #93
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Skip the free Toyota oil changes and do them yourself. Also, get a Tacomaworld sticker for your truck!
    Edit... make sure you drain the oil from under the engine... not the transmission (don't laugh, it's happened) Also, attach around 3' of 5/16" fuel line to the nipple under the oil filter drain... makes oil changes a lot easier with no mess (assuming the filter location is the same for the 2nd and 3rd generations.)
    https://www.tacomaworld.com/threads/halp.33318/
    mquibble likes this.
