New Tacoma owner her and have been lurking about a week and want
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaG3, Feb 27, 2016.
  1. Feb 27, 2016 at 5:56 PM
    TacomaG3
    TacomaG3 [OP] Member
    Larry
    2006 Tacoma SR5 4wd
    To say this forum is GREAT find ! A Big hello to all ! Now for my 1st question. As mentioned I am a new owner and am wanting to change my oil. My "new to me " Tacoma 4.0L has 195K and I have no idea what oil has been used in the past and would like some advice as to whether or not go with synthetic oil when I change oil ?
    Thanks in advance
    TG
  2. Feb 27, 2016 at 5:58 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Welcome :cheers:
    TacomaG3[OP] likes this.
  3. Feb 27, 2016 at 6:07 PM
    TacomaG3
    Larry
    2006 Tacoma SR5 4wd
    Thanks beertime :thumbsup:
  4. Feb 27, 2016 at 6:10 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Welcome to TW and you can use either synthetic or non synthetic, it's up to your wallet :thumbsup: I personally use Valvoline Synthetic or Mobil 1 Synthetic
  5. Feb 27, 2016 at 6:11 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    Mobil 1 synthetic
  6. Feb 27, 2016 at 6:15 PM
    TacomaG3
    Larry
    2006 Tacoma SR5 4wd
    Thanks
  7. Feb 27, 2016 at 6:15 PM
    TacomaG3
    Larry
    2006 Tacoma SR5 4wd
    Thanks
  8. Feb 27, 2016 at 6:19 PM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    Welcome I use Mobil1 Extended Performance Synthetic
  9. Feb 27, 2016 at 6:20 PM
    TacomaG3
    Larry
    2006 Tacoma SR5 4wd
    Thanks
  10. Feb 27, 2016 at 6:34 PM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    Welcome. When I have received my "free" oil changes from Toyota, I'll be changing the oil myself. I'll be using a synthetic. Probably Mobile 1. I'll just have to make a decision at that time.
  11. Feb 27, 2016 at 6:47 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    First time you change oil, make sure that you find the oil pan, not the trans pan.
  12. Feb 27, 2016 at 8:02 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    The reality is if you are very good about changing oil every 3k, there is no benefit to synthetic. Conventional oil protects just as well. Yes you can go further between changes using synthetic but even then I would not go past 5k.
    raskal likes this.
  13. Feb 28, 2016 at 2:20 AM
    TacomaG3
    Larry
    2006 Tacoma SR5 4wd
    hmmmmmmmmm point well made :thumbsup: I will watch youtube to make sure of location :fingerscrossed:
  14. Feb 28, 2016 at 4:04 AM
    P33Rob
    P33Rob Well-Known Member
    Rob
    Watertown, NY
    13 Tacoma V6 TRD 4X4
    OME 3" Lift; Maxfit aeromax; Volant CAI w/scoop; TRD Exhaust; Step rails; SCS stealth 6 wheels; Bedrug
  15. Feb 28, 2016 at 4:31 AM
    Marker4
    Marker4 Member
    2015 taco
    Synthetic oils are FAR superior to conventional oils! The only issue with switching is somtimes synthetic oils tend to cause leaks out of gaskets that are used to Dino oils. I think if it was my truck I would not chance it with that amount of miles.
  16. Feb 28, 2016 at 5:05 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Do you take it to 15k miles between changes?
  17. Feb 28, 2016 at 5:13 AM
    PackCon
    Connor
    Sounds like a personal problem.
    Synthetics do have the advantage over dino that they can last substantially longer. Just because you have a psychological issue with it doesn't mean synthetic doesn't have benefits.
    Keep changing your oil at 3k so you can feel warm and fuzzy on the inside. I'll change mine every 10-15k and have just as much engine longevity as you.
    Sugar Silva likes this.
  18. Feb 28, 2016 at 5:13 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Welcome to TW
  19. Feb 28, 2016 at 5:14 AM
    McTeague
    Alan
    Stock
    No I change at 10k
  20. Feb 28, 2016 at 5:16 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Even Dino oil can go longer then 3k. Places recommend 3k so they sell more oil.
    Send your oil to an oil test facility, and find out how far you can go with it. It'd probably surprise you.
