New Tacoma owner here for some lift advise
Discussion in 'New Members' started by 3dGee, Aug 1, 2022.
  1. Aug 1, 2022 at 7:24 AM
    3dGee
    3dGee [OP] New Member
    Gerald
    22 white Tacoma pro
    So far just raptor lights and viper cut … more coming soon .
    Hey everyone , I just got a 22 Tacoma pro and I’m going to want to lift it up a little bit more to fit 33s . The trd pro suspension is really nice and I don’t want to ruin the ride , is there a spacer lift that I can get a couple inches from without ruining the ride ? Thanks .
  2. Aug 1, 2022 at 7:28 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Leave it stock
    buckhuntin-tacoma and TedChon like this.
  3. Aug 1, 2022 at 7:32 AM
    3dGee
    Gerald
    22 white Tacoma pro
    I want to run 33s can I do that with stock ride height with just trimming? I got the viper cut done this weekend but I think I will need a cab mount chop .
  4. Aug 1, 2022 at 7:34 AM
    02hilux
    Planet: EARTH
    Kwikvette likes this.
  5. Aug 1, 2022 at 7:48 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Lifting a vehicle doesn't mean you can put larger tires.
    If you want real clearance...
    40s n tons :burp:
  6. Aug 1, 2022 at 9:08 AM
    3dGee
    Gerald
    22 white Tacoma pro
    Yea ok but I want to lift it a little and put 33s on it .
  7. Aug 1, 2022 at 9:10 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah, no one's stopping you from doing that.
    Just pointed out that a lift doesn't mean you can put larger tires.
    Depending on the tire, you should able to run 33s easily. At most you'll need to do a CMC.
    3dGee[QUOTED][OP] likes this.
  8. Aug 1, 2022 at 9:27 AM
    3dGee
    Gerald
    22 white Tacoma pro
    Is there a spacer lift for the pro that won’t ruin the ride ?
  9. Aug 1, 2022 at 10:53 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    3dGee[OP] likes this.
  10. Aug 1, 2022 at 11:00 AM
    Darksport
    Darksport Well-Known Member
    Jake
    NE Ohio (Cleveland)
    2017 Black Tacoma TRD Sport 4x4
    33” BFG Ko2s,16” Method NV wheels, CMC, King 2.5 Remote Reservoir, Baja Kits UCAs
    No. And all Tacoma suspension geometry is the same btw. From the sr5 to the Pro. Same ish different hardware. You’ve got a few options. Leave it at the height it is and get tires as large as you can fit with minor cutting. Or get a spacer lift and have the alignment tech push your tires forward with as much castor as it will allow. Or do the lift correctly by getting new coilovers that will allow you to set your ride height where you want, install new upper control arms for more castor and do a cab mount chop to clear the larger tires. That’s about it. Seriously don’t overthink it or you’ll drive yourself mad
  11. Aug 1, 2022 at 11:02 AM
    3dGee
    Gerald
    22 white Tacoma pro
    Thank you .
    Darksport[QUOTED] likes this.
  12. Aug 1, 2022 at 11:02 AM
    TXTaco211
    TXTaco211 Well-Known Member
    Corpus Christi, Tx
    13 Pyrite Mica TRD Sport DCSB
    Kicker Speakers, 5100's with HS coils and HS AAL, Caliraised 30" LED light bar
    Most will say any spacer kit will ruin the ride. There are a lot of threads about lifts and kits used with a quick search on the search function depending on what you are looking for and google does a good job at finding threads with in the forum as well. Personally I would be hesitant to put a lift on that is more than spacers for the Pro as the FOX shocks are pretty good quality and you will be paying a few grand to do a lift that most on here would recommend which would be a full suspension replacement to achieve the lift (to the same quality of shock you have already)
    Keep in mind you will more than likely need to replace upper control arms as well to prevent any rubbing issues. Good luck in your search.
    3dGee[QUOTED][OP] and Darksport like this.
  13. Aug 1, 2022 at 11:10 AM
    3dGee
    Gerald
    22 white Tacoma pro
    Thanks bud !
