New Tacoma owner....Well sorta
Discussion in '1st Gen. Tacomas (1995-2004)' started by Skyed03, Aug 9, 2011.
  1. Aug 9, 2011 at 8:58 AM
    Skyed03
    Skyed03 [OP] Sick,.. Bro....
    Jeremy
    Nor, Cal
    Runner
    Hey guys, newbie here. Im posting for my little brother who just got his first truck. Its a 2000 Tacoma xcab, TRD, V6, Auto. It's in near perfect condition for an 11 year old truck. Its got some miles on it though - 180K. When i checked it out i couldnt believe how clean it was. No leaks, nothing broken or missing and its a complete virgin. Other then all fluids, brakes, plugs an so on.. and new tires what do i need to look for/ do to this thing? I can do all the work myself so thats not an issue. He has no money, so i was guna order up some bilstein struts as a first car gift. If i put the bilsteins on the highest lift setting will it destroy the stock arms or will it be ok? Thanks for any input guys.
  2. Aug 9, 2011 at 9:19 AM
    ERIC
    ERIC Well-Known Member
    Eric
    Orange County, CA
    2002 Impulse Red TRD PreRunner SOLD
    Pioneer double din navi head unit and four 5x7 alpine speakers, westin light bar, procomp lights, head and tail lights, black billet grille, billet antienna, gibson headers and cat back exhaust, afe cold air, uni chip programmer, Bilstein 5100's, Pro comp wheels and tires, tint, blacked out emblems, innu roof rack, yakima basket, foglight mod...
    Welcome! and no the arms will be fine. Im running the same setup. Kind of a rough ride though. Look into the Eibach coils they are longer then stock and run alot smoother.
    Check out downsouthmotorsports.com
  3. Aug 9, 2011 at 1:26 PM
    Skyed03
    Jeremy
    Nor, Cal
    Runner
    Thanks for the info. i was looking at the springs also being as the stock coils have sagged a bit. As far as mileage issues, is there anything i need to look out for? Ive read a few things about timing belts needing to be done around this mileage. What all does everyone replace while they are in there other then the timing belt?
  4. Aug 9, 2011 at 2:04 PM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    Water pump, definitely. Sprockets and tensioners or whatever your truck has, if they look worn.
  5. Aug 9, 2011 at 2:17 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    x2 T belt is a 90k-mile maintenance item.
    Throttle body cleaning is also standard maint. but no reguala interval is given.
    If the coils and leafs are original stock, they are likely worn-out mush. I fhe doens't have any money, at least get some good shocks on the thing so it has better traction.
    If you go to toyotaownersonline.com and register (free), enter the truck's VIN, and you should get any maint. records of what Toyota has done, and any recalls, and also you can get the standard maintenance schedule.
    And check this out:
    http://www.tacomaworld.com/forum/1s...y-how-thread-compiled-list-helpful-links.html
