New tacoma owner
Discussion in '4 Cylinder' started by drtydru, May 12, 2011.
  1. May 12, 2011 at 10:11 AM
    drtydru
    drtydru [OP] Well-Known Member
    Dru
    Oakland
    08 4x4
    Bucket seats, Variable speed wiper switch, 09 led Tail Lights, Satoshied front grill, DDM HIDs, Fog light install, Mud flaps removed, 1.5'AAL, Billie 1552, Toyotec front coilovers w/Billies, B.A.M.F welded sliders w/kickout,
    Hello,
    I am new to the forum and I just picked up my first tacoma. Its an 08 regular cab, 2.7, 4x4 manual.
    I was wondering what mods you all would recommend. I am going to be using it as a daily driver and to go camping/dirt biking on the weekends. I wont be doing any heavy four wheeling but I will be on fire roads and some rutted areas.
    I am mainly looking for more power and better fuel economy.
    Any info would be very helpful.
    Thank you all
  2. May 12, 2011 at 10:15 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Welcome aboard Andrew!!:cheers: Got a picture of your truck?
  3. May 12, 2011 at 10:18 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Traditional power enhancing mods increase the inflow of fuel and air (ie new manifold and carb) and the outflow of the exhaust (new headers). Toyota has the inflow well covered with their fuel injection system and their stock exhaust system is so well designed that adding headers and a new exhaust system do not return any extra power until the revs are really high. Unless you are going to do a full-blown build up of the engine (ie boring, polishing, balancing) you are not going to get much increase.
    Sorry.
  4. May 12, 2011 at 10:23 AM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    :cheers::cheers:Welcome to the club!
  5. May 12, 2011 at 10:25 AM
    drtydru
    Dru
    Oakland
    08 4x4
    Thanks. Pictures to come soon
  6. May 12, 2011 at 10:28 AM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
  7. May 12, 2011 at 10:53 AM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    07 Tacoma 4x4 SR5 V6 Off Road
    Lift,Winch,Shell,Light Bar,Siren,Radio's
    Welcome to TW! :)
  8. May 12, 2011 at 10:57 AM
    DellGSG5
    DellGSG5 Well-Known Member
    Dell
    San Diego, California
    2009 PreRunner TRD
    Step rail, Grill guard, bug deflector,bed lights, Window Deflectors.
    Welcome to TW!!!
  9. May 12, 2011 at 12:16 PM
    o5iiawah
    o5iiawah Well-Known Member
    Tim
    Philly 'burbs, PA
    '11 4x2 access cab 2.7l
    most mods out there pretty much wreck your gas mileage (lift, tires, etc)
    If you need a solid daily driver, go with an interior sound system or a head unit. If mileage is important to you, I dont see you spending thousands upon thousands on light racks, skid plates, roof rails, lift, locker, off road tires and a satoshi grill
  10. May 12, 2011 at 12:22 PM
    booboy
    booboy Well-Known Member
    PaCiFiC nOrThWeSt
    2010 TrD SpOrT 4x4
    Hello!:wave:
  11. May 12, 2011 at 12:25 PM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
