New Tacoma owner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Colt96, Dec 25, 2015.
  1. Dec 25, 2015 at 5:20 PM
    Colt96
    Colt96 [OP] Member
    2007 silver double cab long bed TRD
    none
    I recently purchased a 2007 TRD, I live on a farm and do a lot of off-roading. The truck is on 245s, off-road the front suspension is smooth, but the rear feels like it's going to get snatched out...is that due to bad shocks possibly? Also I am thinking about lifting the truck and running 265 or 275s what lifts are recommended? I read a thread that said not to do spacers. How bad would a doing this mess with my fuel economy? I am in college and have a limited budget. Thanks
  2. Dec 25, 2015 at 7:42 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If its a true TRD then 245s are the wrong size tires.
  3. Dec 25, 2015 at 8:01 PM
    kamiqazi
    kamiqazi Member
    2007 TRD PreRunner
    What size do you recommend? I am also in the market for new tires and was looking into 265/70-16 or 265/75-16 BFG All Terrains.
  4. Dec 25, 2015 at 8:11 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Is it a 4 banger?
  5. Dec 25, 2015 at 8:12 PM
    kamiqazi
    kamiqazi Member
    2007 TRD PreRunner
    Nope, a V6 Double Cab.
  6. Dec 25, 2015 at 8:16 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    265/75/16 will fit stock with no lift. If you off-road, then you should buy Bilstien 5100 shocks for the lift. If your truck is really a TRD model, your tires should've already been that size btw, so you should get stock MPG.
    Is it a Sport (hood skewp)
    Or OffRoad (rear locking diff)
  7. Dec 25, 2015 at 8:18 PM
    kamiqazi
    kamiqazi Member
    2007 TRD PreRunner
    Off Road. I plan on adding 5100s to both the front and the rear in a about six months though.
  8. Dec 25, 2015 at 8:20 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    I suggest saving your money until then. Don't waste your money on a spacer lift if you plan to change out the shocks soon anyways. How much do you plan to lift?
  9. Dec 25, 2015 at 8:21 PM
    kamiqazi
    kamiqazi Member
    2007 TRD PreRunner
    I was thinking just 1 inch in the front. Not looking for anything too drastic.
  10. Dec 25, 2015 at 8:22 PM
    kamiqazi
    kamiqazi Member
    2007 TRD PreRunner
    Any suggestions on where do buy them and/or have them installed?
  11. Dec 25, 2015 at 8:24 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Just stick with 265/75/16 then and you will be fine. You can try a 32" tire if you're okay with trimming a bit. As for the actual tires, I've heard nothing but good about the new BFG KO2s. That's what I plan on buying next.
  12. Dec 25, 2015 at 8:26 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    I'm not sure. It depends on your area I guess. Theres probably a thread on here to show you how to install them yourself if you got the tools and time.
  13. Dec 25, 2015 at 8:32 PM
    kamiqazi
    kamiqazi Member
    2007 TRD PreRunner
    I'll look around. Thanks for the help!
    DustStorm4x4[QUOTED] likes this.
  14. Dec 25, 2015 at 8:33 PM
    Taco2Taco79
    Taco2Taco79 Active Member
    The Green State
    2015 TRD Sport MGM DCSB
    Bilstein 6112/5160 ..275/65/18 DuraTracs on MB KO rims...NFab Bars...WetOkoles
    On my 05' I had 265/75/16 Toyo AT's.... no lift... no rub at all
  15. Dec 25, 2015 at 8:46 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    No problem.
  16. Dec 25, 2015 at 10:15 PM
    timhom19
    timhom19 Well-Known Member
    tim
    Beaumont, Ca
    2010 DCLB
    On my 2010 I have 265/75 16 duratracs no rubs
  17. Dec 26, 2015 at 3:11 PM
    Colt96
    Colt96 [OP] Member
    none
    I figured 265 was stock because my speedometer is off. Guy who had it before downsized the tires for better fuel economy I guess.
  18. Dec 26, 2015 at 3:44 PM
    Colt96
    Colt96 [OP] Member
    none
    Thanks! I'm still trying to learn how to work this forum stuff. I got a picture of it uploaded into my profile and media I think. Its with my old truck. Haven't had time to take many good pictures
  19. Dec 26, 2015 at 3:48 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    The tire sizes are also on the vin :D
  20. Dec 26, 2015 at 3:51 PM
    Colt96
    Colt96 [OP] Member
    none
    Okay thanks! The Bilstein 5100 Shocks, you said for the lift, you mean have them along with the lift or they lift?
