New Tacoma SR5 next Tuesday, what about undercoating?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SonOfEru, Feb 11, 2023.
  1. Feb 12, 2023 at 8:25 AM
    #41
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    For less than $80 you can buy a gallon of FF and the gun and coat it many times. On the ground turn the wheels lock to lock it's a bit tight but you can get every thing covered. Only thing I would worry about first go around a garden hose wash then let it dry. Damn I just had mine on the lift I should have taken pictures. 12 years of Maine winters frame's blacker than it was new.
  2. Feb 12, 2023 at 9:01 AM
    #42
    SonOfEru
    SonOfEru [OP] Well-Known Member
    Sanbornton NH
    2023 Silver SR5 Access Cab
    OK, that's a bit sobering. 1k would be noticeable in my budget. And I think I know the place you mean -- Truck Trends in Tilton NH
    Change of topic. Talking with a friend, she asked what is already on the truck for protection. So is there anything that Toyota applies to any of the metal at the factory?
    On my '02 SR5, up under the front fenders, the sheet metal is not smooth, it's kind of a rippling surface, over which there is the red paint. It's hard; I doubt I could chip it off with a hammer and chisel. I'm presuming that rust treatments have to cover the sheet metal, not just the steel of the frame and springs and all.
    And I should avoid any kind of electrical connectors (are there any?) And what about things like connectors in brake lines, or any other kind of connector that needs to be connected and disconnected (are there any?). You can see I'm not very fluent in what's all the stuff down below. I don't know what a chin spoiler is.
    And hard to get to places - over the tops of things, like the gas tank? Or between the leafs of the springs (do you say leaves or leafs?). I saw one video where the guy said it really helps to have the sprayer wand for that, right? And the sprayer isn't too expensive.
    I guess the answer is -- go find videos
  3. Feb 12, 2023 at 9:12 AM
    #43
    SonOfEru
    Sanbornton NH
    Well, if the BossWax/NHOU job is really one time for $1000, with warranty to touch up for free, that is less worrisome. Sounds like all the others are to repeat every year, so if I get 10 years then that's $100 a year. And my '02 SR5 lasted 20 years (I would be interested to see the warranty still good then ... )
  4. Feb 12, 2023 at 9:24 AM
    #44
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    I did nothing to my 2021. Although I do live on Long Island, but Ive never under coated any truck or Jeep that Ive owned. I would just take it to the pay and spray car wash periodically during the winter to get the salt off. Frame looks practically spotless
  5. Feb 12, 2023 at 9:30 AM
    #45
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I’m guessing they’re not spread salt in your area?
  6. Feb 12, 2023 at 9:31 AM
    #46
    AM6217
    They do, but its a mixture of sand and salt. Some towns use Beet Juice.
  7. Feb 12, 2023 at 9:34 AM
    #47
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    OK, cool great to know.
    Down here in the Midwest, there’s a major issue with corrosion from salt and brine.
  8. Feb 12, 2023 at 9:35 AM
    #48
    AM6217
    If I resided where you are or further up north , I would coat the frame.
  9. Feb 12, 2023 at 9:35 AM
    #49
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Give your frame about 3 more years. I live just north in connecticut, I know about how much they like salt here.
  10. Feb 12, 2023 at 9:49 AM
    #50
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Lots of good options and avoid anything 'rubberized' as suggested. Personally I've used the PB Blaster Surface Shield since a frame replacement in2020. Supposed to hang on longer than most from my research. Ohio uses the frame killing brine here, so.....:mad:
    https://blasterproducts.com/product/surface-shield/
  11. Feb 12, 2023 at 9:50 AM
    #51
    86_MR2
    86_MR2 Swallow my tranya
    North Chicagoland
    2022 TRD Off Road M/T, Neil Armstrong Edition
    If you’re going to do it yourself I think a thing to consider is just how many times you are going to want to repeat the task. There’s a difference in doing this job with a pristine undercarriage vs one that’s coated with crud. Things wont be as visible.
    Personally, I don’t want to keep having to spend my time and money. I’d rather pay upfront for a complete and quality job than have to half-ass it year after year.
    Your undercarriage should be ready to go if you do the job very shortly after you take delivery. If you want to be extra sure it’s nice and clean and have a pressure washer there are wheeled undercarriage sprayer attachments available on Amazon to get under there and hose it down. That’s what I did. Just let it dry for a day or two then go at it with the Cosmoline.
    Check out the links in my previous posts. There are other links that point to the Chemicar site and cosmolinedirect.com for the materials & equipment.
  12. Feb 12, 2023 at 11:21 AM
    #52
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    FYI high content carbon actually means more prone to rust but yields a stronger alloy.
    Just get undercoating by Krown or similar once or twice a year and forget about it. It's not rocket science.
  13. Feb 12, 2023 at 12:17 PM
    #53
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    Not sure how effective this may be, but I've heard of people adding a simple jar of ordinary cinnamon spice to Fluid Film to minimize the odors.
    faawrenchbndr likes this.
  14. Feb 12, 2023 at 12:49 PM
    #54
    SonOfEru
    Sanbornton NH
    Sugar and spice and everything nice
    Yes I will
  15. Feb 12, 2023 at 12:55 PM
    #55
    86_MR2
    North Chicagoland
    I prefer Hai Karate to fend off both the stench and rust.
    Be careful how you use it.
  16. Feb 12, 2023 at 1:03 PM
    #56
    SonOfEru
    Sanbornton NH
    I just found that WoolWax has a dealership in the area. I haven't heard much about that one here. Are there any cheerleaders among y'all for that one?
    And I do sorta wonder with BossWax in the game, are they any way similar? And if so how does WoolWax need annual application, and BossWas is marketed as a one time forever job, and warrantied too. I guess I will learn some once I can get some of these folks on the phone tomorrow.
    And I say y'all whenever I can, cause I was born and growed up in Etlanna (the proper pronunciation for Atlanta). I don't ever hear it here in NH, so I'm taking the opportunity
  17. Feb 12, 2023 at 2:21 PM
    #57
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  18. Feb 12, 2023 at 2:24 PM
    #58
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Hate to ask how much is a can of PB Blaster? It will take several cans.
    That one old guy likes this.
  19. Feb 12, 2023 at 2:35 PM
    #59
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    You can get it at harbor freight for $8.50 right now if you're a member. $10 if not
  20. Feb 12, 2023 at 4:05 PM
    #60
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    Oh man! And Marietta was Meretta, or even Mretta, not Mary-Etta. (At least for my grandmother, who was from Albama.) :)
