New Tacoma Stumbling Start Issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YourActualName, May 26, 2015.
  1. May 26, 2015 at 7:12 AM
    YourActualName
    YourActualName [OP] Well-Known Member
    NH
    2015 Black Tacoma Limited DCLB
    Magnuson SC, +
    Problem:
    I park at a slight 10 degree angle with the drivers side being on the elevated side. Every once in a while after about 1 day of not driving it I will go to start it and it stumbles for about a second before it fires up. Reason for mentioning parked at an angle is that I haven't had this happen parked flat...yet. Starter isn't slow, haven't tested battery. My other two Tacoma's before this never had a hesitation before starting. (07 V6, 01 4 banger)
    Questions:
    What could be causing this issue?
    Fuel shifting from one side to another? (Even does this with a full tank)
    Vacuum leak/Hose not tight?
    Info:
    2015 Tacoma - 3000 miles - V6 - Auto
  2. May 26, 2015 at 7:18 AM
    Ping
    Ping The root of all suffering is expectation.
    Ohio
    15 Taco TRD Pro
    TRD Supercharger
    I park on a 10-15 degree incline as well and I have the stumble whenever I start. I will try parking nose down for the next week to see of that changes it.
    tacoma09medic likes this.
  3. May 27, 2015 at 1:30 PM
    YourActualName
    NH
    Magnuson SC, +
    At least it's not just me with this issue!
  4. May 27, 2015 at 1:59 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    interesting, my drive is only about 3 degrees but I park on a slope quite often and have NEVER had this issue :confused:
  5. May 27, 2015 at 2:06 PM
    oh crap its him
    oh crap its him Well-Known Member
    Shannon
    OH->SLC,UT->SA,TX
    09 TRD OR
    Lift, Wheels, Lights
    I park on a slight incline at work and mine does it maybe once a month when its cold out. No issues during the summer. New battery and resetting the ECU didn't improve anything...
  6. Nov 4, 2015 at 3:09 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Anyone else have this issue or know what is going on? Mine has done this once in a while since I bought it. It has never failed to start, but once in a while it will stumble like it is flooded and then rev and smooth out. It usually happens after it has sat all day like after work or in the morning.
  7. Dec 16, 2015 at 5:38 PM
    Notoneiota
    Oakdale, MN
    Instead of starting a new thread I'll try to keep this one going...has anyone found a possible solution to this? My truck starts fine unless it has been sitting all day. It did it today when I left work. Cranks and cranks faster and faster until it barely sputters to life. Sounds like a POS old car. Embarassing for a new truck with 24k.
    Today's details: Started perfectly this morning. Sat exactly 8.5 hours in a flat, asphalt lot facing east. Temp was 37 degrees. Rained off and on all day. Gas tank is 3/4 full. I always turn the key and let it sit for 2 chimes to let the fuel pump charge (old habit from owning Jeeps). Cranked and cranked faster and faster and barely seemed to catch and sputtered to life. No check engine light.
    I have a warranty (only at 24,740) but really don't want to leave it with dealership only to be told they can't replicate it. What can I do to test it on my own?
  8. May 4, 2016 at 6:15 PM
    YourActualName
    NH
    Magnuson SC, +
    Update: Still does it from time to time but I don't want to take it to a dealership for them to say they can't replicate it. 15k miles on her now.
    Anyone else?
  9. May 4, 2016 at 8:26 PM
    Liquix
    Liquix Well-Known Member
    Connecticut
    14 ACOR 4x4 v6
    My new 2014 Tacoma did this for a while and eventually stopped, maybe after two-dozen times? It hasn't happened in a long time and I'm around 25k now.
  10. May 4, 2016 at 9:34 PM
    Gusman4
    Gusman4 Member
    My 2015 with less than 10k does this intermittently. Slope makes no difference seems to do it when cold out and hasn't been driven for a bit. I too haven't brought it in to Toyota as I fear the "started fine" response. It hasn't done it in the last month.
    My seat clicks when I go around corners all the time and they said they couldn't replicate that so I don't have a lot of faith in them figuring this one out.
    Sorry not much help.
  11. May 4, 2016 at 10:13 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Mine does this as well when starting it up in the morning on my sloped driveway. Sounds like it's trying to start but is sluggish to get going.
  12. Aug 25, 2016 at 4:52 PM
    YourActualName
    NH
    Magnuson SC, +
    Update to this, I've since moved from the apartment and by parking on flat this has stopped completely.
  13. Aug 25, 2016 at 8:07 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Sounds like a check valve issue for the fuel pump.
  14. Aug 26, 2016 at 4:25 PM
    Notoneiota
    Oakdale, MN
    I haven't had an issue since my initial reports. Seems to have worked itself out. Weird.
  15. Aug 26, 2016 at 4:45 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Strange. Ive had 2 tacomas. A 2011, and my current 2013. Both have/had occasional stuttering starts. Mine seem completely random. Ive read many people have the same. Its never failed to start.
  16. Aug 18, 2017 at 8:57 PM
    Ping
    Ohio
    15 Taco TRD Pro
    TRD Supercharger
    2.5 years down the road and this issue cleared up on its own a long time ago.
  17. Jul 17, 2023 at 12:19 PM
    Joey sanchez
    Joey sanchez New Member
    Your Taco's are probably suffering from bad injectors, they are leaking fuel into the cylinders while parked. Mine was doing the same thing. $2000 later it is fixed. Not sure if it was worth fixing but is really nice for it to start correctly.
  18. Jul 17, 2023 at 12:31 PM
    Tacospike
    Two Trucks
  19. Jul 17, 2023 at 12:46 PM
    YourActualName
    NH
    Magnuson SC, +
    Revived from the depths.
    Guess I'll toss in an update, 102k hasn't happened since 2016.
