New Tacoma to be shown in Detroit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoRan, Dec 4, 2014.
  1. Dec 9, 2014 at 8:57 AM
    #161
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    It just dawned on me that in 2003 toyota came out with a new 4runner body style then two years after came out with the 2005 tacoma which was largely similar, but had slightly better styling.
    In 2014 the new 4runner design came out and 2016 would be the same amount of time for them to come out with a new tacoma based of the same design. I expect the new tacoma to look similar to the new 4runner.
    It could very well look similar to this.
  2. Dec 9, 2014 at 9:14 AM
    #162
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    EGR?
  3. Dec 9, 2014 at 9:19 AM
    #163
    nad
    nad mmmm tacos!
    Jordan
    Canada
    ya it was the egr, after that happened he bought after market turbos, installed a programmer and did an egr delete.
  4. Dec 9, 2014 at 9:23 AM
    #164
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    If they are going to put on that front end off the 4Runner, then I want the transfer case shift lever it has instead of the dial.
  5. Dec 9, 2014 at 9:56 AM
    #165
    la0d0g
    running for the hills
    For crawling not hauling
    My 2013 T4R has a dial too. Do the new ones have a shift lever?
  6. Dec 9, 2014 at 11:11 AM
    #166
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Not if you buy used. I honestly don't see how people afford new diesels that cost 60k, the old ones were better anyway. I'd take my 7.3 over any of the new diesels out there, I know it will likely still be running 20 years from now and most of them will be in a scrapyard somewhere.
  7. Dec 9, 2014 at 11:12 AM
    #167
    2004TacomaSR5
    Jon
    Montana
    I actually really like that. Just hope they do something else with the cab and bed other than a front clip.
  8. Dec 9, 2014 at 12:01 PM
    #168
    nad
    nad mmmm tacos!
    Jordan
    Canada
    Trail editions do.
  9. Dec 9, 2014 at 12:20 PM
    #169
    la0d0g
    Good to know. The wife wanted a limited so a dial it is :pout:
  10. Dec 9, 2014 at 3:55 PM
    #170
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    The next Tacoma is all new. It's on the record from Toyota corporate. It won't recycle any sheet metal from any existing Toyota.
  11. Dec 9, 2014 at 3:56 PM
    #171
    ThomasMore66
    Dallas/Fort Worth & Durango
    Ok.
  12. Dec 9, 2014 at 3:58 PM
    #172
    TacoJonn
    Jon
    Laramie, Wyoming
    That is actually a big bit of clearance difference if you have ever taken your truck off road. I do like the Colorado ZR2 concept though. Looks like it could function in environments outside of the sprawling strip malls and subdivisions.
    I live in Wyoming, and spend my leisure time in the mountains. I can't have a sissy truck like a Coloraydo. I need a Taco. Reliable, capable, and damn sexy.
  13. Dec 9, 2014 at 3:59 PM
    #173
    nad
    nad mmmm tacos!
    Jordan
    Canada
    The tacoma in 2005 was all new too, but based heavily off of the 2003 4runner.
  14. Dec 9, 2014 at 4:02 PM
    #174
    TacoJonn
    Jon
    Laramie, Wyoming
    You guys are a bunch of downers lol. Do you NOT want a new Taco? Do you want them to keep this body style another 10 years? Sheesh.
  15. Dec 9, 2014 at 4:03 PM
    #175
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    But not anything like the previous tacomas, so if we do the math correctly the 2016 will be "all new."
  16. Dec 9, 2014 at 4:04 PM
    #176
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    I want to see a new design, but I also want to see the current problems on the models for that last 10 years fixed. Why will this one be any different if they still don't have remedies for the current recalls? That makes me believe that the new redesign will have a good chance of having the same problems as these.
  17. Dec 9, 2014 at 4:07 PM
    #177
    TashcomerTexas
    Because the components will be different, why fix something that's going to be switched out with newer parts? They will all have their faults anyways, it's time to move on
  18. Dec 9, 2014 at 4:08 PM
    #178
    TacoJonn
    Jon
    Laramie, Wyoming
    The current Taco has been out-dated for more than 5 years. Gets the same MPG as a GM 5.3 liter V8. It's time for a new Taco.
  19. Dec 9, 2014 at 4:11 PM
    #179
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I'm not so sure the new tacoma is gonna get much better gas mileage. The new 4 runner is pretty close to the current tacoma in mpgs.
    Unless they have some crazy new motor they've been developing.
  20. Dec 9, 2014 at 4:13 PM
    #180
    Fiend13
    Chad
    If that's the case then why not just put whatever leaf springs they're using on the 16's in ours?
