New tacoma/toyota owner w/?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doublejdog, Jun 20, 2008.
  1. Jun 20, 2008 at 4:22 AM
    doublejdog
    doublejdog [OP] New Member
    Thanks for having me. Just upgraded from a Ford Explorer. What a difference. One question though. When I go over a bump i hear a rattle near the rear axle on both the left and right side depending where the bump is. The dealership said it was the shocks and repalced them with the same ones and the rattle is still there. I took the tailgate off to see if that was it. No luck there. They looked underneath and couldn't see anything obvious. Any thoughts? Also when releasing the clutch in gear I can sometimes hear the same type rattle in the middle.
  2. Jun 20, 2008 at 4:24 AM
    missileman125fw
    missileman125fw Well-Known Member
    Welcome to tacomaWorld. I have no idea what the rattle is. I'd go right back to the dealer and have them look at it again.
  3. Jun 20, 2008 at 4:57 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Welcome to the site! I have a similar rattle but mine is due to having my tie down in the bed compartments.
  4. Jun 20, 2008 at 6:20 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Welcome aboard.
    I had a rattle/clunk on bumps when my truck was new and they said it was the springs. They lubed them with something and it stopped.
  5. Jun 20, 2008 at 6:22 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    Welcome to TW....glad to have ya:D
  6. Jun 20, 2008 at 1:27 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Welcome to Tw. I also have no clue how to stop your noise.
  7. Jun 20, 2008 at 1:43 PM
    SithL0rd
    SithL0rd Member
    Memphis, TN
    2008 2.7L Acc Cab, Black Sand Pearl
    I just got mine yesterday(pics later) and I had the same problem. At first I thought it was the rings in the bed but it ended up being the hooks? that mount to the sides of the bed stuck in the compartment in the bed.
  8. Jun 20, 2008 at 4:22 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    I kind of noticed that same noise. I too have a 6spd, and it does it when I pop the rear over a bump, and sometimes when releasing the clutch. I am starting to think it's within the drive shaft. No springs in rear, so Not sure if lubing the front springs will stop a rear noise. But keep me posted, mine only happens on those big speed bumps and if I aproach to fast on the rumble strips.
    Oh yeah; Welcome to TW
  9. Jun 20, 2008 at 5:17 PM
    YotaMan08
    YotaMan08 Member
    Hartselle, Alabama
    08 Reg Cab 4x4 5spd
    Coming Soon
    I haven't noticed anything like that on my tacoma yet, but some of the other trucks i had did something similar and i figured out it was the reciever in the trailor hitch. Like when i would go over a speed bump it would rattle a lil bit........Just an idea!
  10. Jun 9, 2011 at 5:03 PM
    iliketurtles
    iliketurtles Well-Known Member
    Bought a 2011 Tacoma and it too rattles while going over speed bumps. Only a narrower bump will cause it, and it sounds like it's coming from the middle or front of truck. I crawled underneath to look for anything that might be loose and found nothing. The dealership had no idea what it was.
  11. Jul 10, 2011 at 8:16 PM
    iliketurtles
    Wondering if anyone else has had this problem
  12. Jul 10, 2011 at 8:18 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    No chance the spare is loose in the carrier ?
  13. Jul 10, 2011 at 8:27 PM
    iliketurtles
    Hm..I'll check. Thanks.
