New Tacoma/Tundra factory LED bed light kit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trrubicon06, Jun 3, 2015.
  1. Nov 25, 2016 at 10:03 PM
    #201
    faultball
    faultball Well-Known Member
    WHT2017SR5DCLB2WD
    Is it a 2015?
  2. Nov 26, 2016 at 1:43 PM
    #202
    Ohiophil
    Ohiophil This space intentionally left blank
    Phil
    Central Ohio
    2015 Tacoma PreRunner
    Give me some money so I can fill in this info
    Sure! I recommend mashed potatoes though
  3. Dec 3, 2016 at 8:13 PM
    #203
    Jose Pietro
    Jose Pietro Active Member
    Jose
    2016 White Tacoma Limited
    Does anyone have a diagram of how to install these lights? I want to install them on a 2016 Tacoma
  4. Dec 3, 2016 at 9:16 PM
    #204
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I haven't installed mine yet, but the instructions seem pretty complete.
  5. Dec 3, 2016 at 9:54 PM
    #205
    Ohiophil
    Phil
    Central Ohio
    if I installed these over again, I would shorten the wiring. I had about 4 feet to bundle up. Not a huge deal, but still. Simple install though. A couple taps and a few holes and bam!
    Norton[QUOTED] likes this.
  6. Jan 7, 2017 at 11:12 PM
    #206
    Norton
    Nicely done by both of you! I had TRDSparks add the light kit to the supercharger I bought during last fall's GB, and I picked-up the same/similar switch from Amazon. ALL of it is sitting in my garage, waiting for warmer weather to install.
  7. Jan 13, 2017 at 6:23 AM
    #207
    JS760
    JS760 Well-Known Member
    San Diego
    2017 DC Sport
    I just need a sanity check here guys, I was going to install mine this morning and I do not have a 7/16th bit. And 7/16th is a pretty large hole, do I really need to go that big?
  8. Jan 13, 2017 at 1:35 PM
    #208
    bogginator
    bogginator Well-Known Member
    Marsh
    Cherokee County
    2015 Black DCSB XSPX
    It's a never ending $100-$200 a week thing & still going.
    As far as I remember the 7/16 hole is in the middle and is for the wire. It's not required to be that big but you would need to feed the wire loom on from the underside.
  9. Jan 13, 2017 at 6:30 PM
    #209
    Ohiophil
    Phil
    Central Ohio
    The loom is 3/8" if I remember correctly. That's gives you 1/16 clearance. You could always just use a 3/8" bit and then ream the sides to make it fit. Would take an extra 5 seconds per hole
  10. Jan 14, 2017 at 9:24 AM
    #210
    JS760
    San Diego
    2017 DC Sport
    Exactly what I did thanks !
  11. Jan 21, 2017 at 9:46 PM
    #211
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Hmmm...I really late to this party @adio, but I just did an hour's worth of research into this EXACT F150 kit because I love the OEM look of the switch. I personally prefer the Toyota lights, but I really wanted that weatherproof, flush mounted switch. From what you're saying about having to hold it down, it sounds like only a momentary switch? That's a bummer if it is. I did come across some F150 owners saying that in order to get the lights to work with the in-bed switch, Ford has to do some "programming" to their truck. I wonder if they have it hooked up and programmed so that the switch is momentary, but a double-press or press-and-hold would make the lights stay on.
  12. Aug 25, 2017 at 11:33 PM
    #212
    TexTako
    TexTako Well-Known Member
    Houston, TX
    2016 Tacoma MGM 4x4 TRD OR DCSB AT
    Definitely you need to install a relay if you want to keep the lights on without holding down the push button. It seems that this device is not a switch so you will need a relay wired to hold the light on. Better yet, if you use a timer relay so the light goes off after a preset time (says 15 minutes), so you won't care to remember if lights were turned off, as they will turned off automatically after preset time had elapsed.
  13. Aug 25, 2017 at 11:34 PM
    #213
    TexTako
    Houston, TX
    I think that for the Tacoma application you will need a relay.
  14. Aug 25, 2017 at 11:40 PM
    #214
    TexTako
    Houston, TX
    Definitely is a Dealer Add on, very popular BTW. But I ordered my truck from factory and it didn't come with that lights. They're approved by Toyota as part of OEM catalog list.
  15. Nov 30, 2017 at 8:28 PM
    #215
    BCTRDPro
    BCTRDPro Member
    BC
    Tacoma TRD Pro Cement MT
    Does anyone know how many amps the LED bed lights draw?
  16. Dec 1, 2017 at 2:51 PM
    #216
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    not enough to worry about......mine are hooked into dome where it dims like cab does. Have cover on bed so they are like trunk lights. Still haven't changed to a bed switch and separate circuit.
    Norton likes this.
  17. Dec 1, 2017 at 4:42 PM
    #217
    BCTRDPro
    BCTRDPro Member
    BC
    The reason I ask is I'm considering installing an LED strip under the bed rail and would like to tie them in to the same location that these lights (per install instructions ) and then be able to use the bed light switch from cab. I estimate about 1.7 amp draw from he LED strip (4.8W per metre), so I would like to compare theit amp draw to the cargo LED lights. I want to avoid overloading the factory wiring. Thanks.
  18. Jan 16, 2018 at 7:59 PM
    #218
    Tacomavkk
    Tacomavkk Well-Known Member
    Woodinville, WA
    2018 TRD Off-road DCSB Quicksand
    I just ordered a TRD OR and put this in as part of the order. The dealer said accessories that go in the order are covered by the Standard toyota warranty and those put in later by the dealer have a 1 year warranty. It's worth getting this one in on new orders if the DIY seems daunting. The part is definitely cheaper than having it on the list, but I wanted to avoid the install.
  19. Feb 21, 2020 at 10:30 AM
    #219
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    Hows your 4 bed lights working out? Still going strong?
    i ordered 00016-34089 on eBay for my 2016, maybe i should get another set, total 4 bed lights like you.
    https://www.ebay.com/ulk/itm/282228230864
  20. Feb 27, 2020 at 3:30 PM
    #220
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    mine still work great
