New Tacoma/Tundra factory LED bed light kit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trrubicon06, Jun 3, 2015.
  1. Sep 15, 2015 at 7:43 AM
    #81
    Duck76
    Duck76 Active Member
    British Columbia, Canada
    13 Tacoma TRD Sport DCLB
    Looks very nice. Sub'd
    JWROSE4 likes this.
  2. Sep 15, 2015 at 5:01 PM
    #82
    mr2crazed
    mr2crazed Well-Known Member
    Paso Robles, CA.
    06 DC PreRunner SR5
    I love the OEM look.
    Which switch is used to turn on the bed lights? Is it wired straight to the battery or is there a relay?
  3. Sep 15, 2015 at 11:52 PM
    #83
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    install mine and i'll buy one haha
  4. Sep 16, 2015 at 4:38 AM
    #84
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I don't believe there is a switch with this kit. It comes on when you unlock the truck
  5. Sep 16, 2015 at 5:28 AM
    #85
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    the tundra install comes on with door, keyfob, or bed lights (since tundras have bed lights in the chmsl)
    the tacoma doesn't have a bedlight switch, so door/fob only
    you can wire it anyway you want obviously
  6. Sep 16, 2015 at 5:52 AM
    #86
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I guess for 62.00 it's not bad
  7. Sep 16, 2015 at 8:16 PM
    #87
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    just installed.
    they work GREAT
    drill templates are 100% spot on...when you print them, be sure to measure the
    1 inch line provided, and confirm the print is 'what you see is what you get' mine was
    exact.
    only thing odd is when you -first- connect the rear leds to the main harness, (or disconnect
    then reconnect them) key fob won't turn them on. open door, they turn on.
    after that, key fob or door turn them off and on.
    odd how the initial plug-in somehow makes it skip keyfob action until after the
    door is opened once.
    anyhow yes they light up the whole bed. I have a softtopper and it lights up
    the entire inside. and it comes with a Toyota 1 yr warranty on the parts.
    looks exactly like Tacoma bed material so it totally looks stock, fits right in
    Norton, Taco-2013 and adio like this.
  8. Sep 20, 2015 at 8:21 PM
    #88
    Taco Brad
    Taco Brad New Member
    NC
    11 PreRunner TRD AT DC
    Just did this mod today and could not be happier with the results. The termination wires for my 2011 were the same as the instructions for the Tacoma. The hardest part was getting down the frame rail by the gas tank from back to front when running the wiring harness. And because I didn't want to cut the wiring gromet working the additional harness into and through it was a struggle but worth it for no cuts. Otherwise it was a great afternoon mod and I love it tied to the interior dome light. Thanks to all contributors for the info.
    Arkie-Marty and 1truckdriver like this.
  9. Sep 21, 2015 at 5:13 PM
    #89
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    I was going to install the Tundra/Tacoma led cargo bed light kit that I got. Instead I went for the F150 style led cargo bed lights. It ain't cheap but I love that look of it being stock/oem-ish.
    Got them installed yesterday. Yes they do light up the whole bed.
    Passenger side.
    E086FE46-A4D5-41AA-AEC8-668B70E50323_zps_df7e1726a5533d36e8055f82cec4f29851313f4b.jpg
    1ACCDB1B-E85F-45B2-A22F-7BE9E1493E90_zps_ee637679e858ac88daaa705036e6d58969bab984.jpg
    Driver side w/switch.
    40844CB9-E65D-49BD-B8BC-C34AF5E63577_zps_69ddd7f7d19ae84de597c03aa6aef0d97ef5921d.jpg
    A4446B0B-0077-4F9F-BE2A-79BB9C771D49_zps_97b20e1cb568495668b86346d215e48f2be954ed.jpg
    Light output. Yes I know you can get a better light out put, and it's cheaper with led strips. But I ain't a fan of it. I ain't looking to lighting up a whole neighborhood.
    8A77F2A2-5A2A-4A65-9A09-ADD2F58022CC_zps_4e07e5c4e9ef5282d0974d173c401165ee19402c.jpg
    528674AD-3F95-407F-B647-4FDA2BFB8A8D_zps_7148977c6851a125c07526c06251da49a363e0bb.jpg
    B908BF76-639B-4AAB-8129-26AF269F6472_zps_44962f33340e83c5f58c9e1c026fd55ad2acaa38.jpg
    TAC1, TexTako, Norton and 4 others like this.
  10. Sep 21, 2015 at 5:19 PM
    #90
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I'm confused the Tacoma/Tundra kit is OEM ish so why go with the Ford?
    TAC1 likes this.
  11. Sep 21, 2015 at 5:36 PM
    #91
    adio
    HI
    True, but I'm always looking to go in different routes then everyone else. Don't get me wrong not saying anything bad about the Tundra/Tacoma kit(I got that kit the first time I read about it).
    TAC1, swtaco10 and TexTako like this.
  12. Sep 21, 2015 at 5:36 PM
    #92
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    The F150 lights look great. They sit flush, unlike the Toyota OEM ones, so that they are less obstructive when loading items. And that switch is waterproof and sits flush also. A much better fit than OEM.
    Thanks for sharing this with us.
    TAC1 and swtaco10 like this.
  13. Sep 21, 2015 at 5:38 PM
    #93
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    It does look sweet how much is it, and how easy is it to put in? Got a link to it brother?
  14. Sep 21, 2015 at 5:42 PM
    #94
    1truckdriver
    1truckdriver BRO
    Daniel
    Rancho Cucamonga, Ca.
    '15 DCSB Off Road 4x4 SuperWhite
    TRD SuperCharger SCS Rays 10
    Which is the cheapest route? I'm guessing the Toyota version is, but I'm feeling that flush fit on the ford kit
    swtaco10 likes this.
  15. Sep 21, 2015 at 5:45 PM
    #95
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    #95
  16. Sep 21, 2015 at 5:45 PM
    #96
    sixtytooze
    sixtytooze Well-Known Member
  17. Sep 21, 2015 at 6:00 PM
    #97
    adio
    HI
    I paid $188.85 shipped(fyi it's that much because you're paying for a whole kit for an F150). I tried sourcing each part but to no avail. You have to make your own template to have those led pods(that's what I call them) fit flust on the side of the bed. I got them on eBay. Looked back and eBay seller doesn't list them anymore.
    That's a lot lower price then what I paid for.
    The Tundra/Tacoma kit would be your best bet, price wise.
    #97
  18. Sep 21, 2015 at 6:03 PM
    #98
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    How does it hook up? Compared the Toyota kit?
    #98
  19. Sep 21, 2015 at 6:29 PM
    #99
    1bad10tacoma
    1bad10tacoma Well-Known Member
    Mark
    Brewer Maine
    2025 dcsb Trd off-road
    tonneau,
  20. Sep 21, 2015 at 6:31 PM
    #100
    adio
    HI
    Since the kit isn't specific to Toyota, you can pretty much hook it up anyway you want. I ended up hooking it up straight to the battery with an inline fuse to be on the safe side.
    The only draw back is that the lights only come on when you hold down on the switch. Not to sure why it works like that, I guess it's a Ford thing(I'm a newb when it comes to wiring by the way haha). Would adding a relay help in this situation?
    I am thinking of adding an in cab switch under the hazard switch.
    TAC1 likes this.
