New Tacoma/Tundra factory LED bed light kit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trrubicon06, Jun 3, 2015.
  1. Oct 23, 2015 at 5:28 AM
    #141
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Went ahead and picked up one of these kits. Will run it off an unused switch in my lower panel under AC wired to something switched for no dead battery action. I do like the black button switch setup tho.
  2. Oct 23, 2015 at 5:46 AM
    #142
    bogginator
    bogginator Well-Known Member
    Marsh
    Cherokee County
    2015 Black DCSB XSPX
    It's a never ending $100-$200 a week thing & still going.
    Coming off the trailer harness = no dead battery. It only has power when the ignition is on. I went with the bed switch because I already had a full switch bank under the AC. Air on board has some nice switches for this location in my opinion.
  3. Oct 23, 2015 at 10:48 AM
    #143
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    Hmm I may pick one up as well. How bright is it?
  4. Oct 23, 2015 at 11:11 AM
    #144
    bogginator
    Marsh
    Cherokee County
    It's bright enough to see all of the inside of the bed at night. Page 7 has mine and another TW members pics. Here's another one I took last night with just my phone camera no flash.
  5. Oct 23, 2015 at 4:18 PM
    #145
    jk70
    jk70 My Mid-Life Crisis
    The Triangle, North Carolina
    I like these lights but I also want one of those swingcase toolboxes like below. I'm assuming I'll be blocking the light?
    andyr562 likes this.
  6. Oct 23, 2015 at 8:11 PM
    #146
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    You assume correctly! :)
  7. Oct 25, 2015 at 6:42 AM
    #147
    jk70
    Ok. shot in the dark here. I like these bed lights, especially if I can wire my own switch to the interior and one in the bed. I also love this swing out toolbox (perfect for all my pop up camper tools). I don't mind that this would block the light as I can always swing it open if I needed more light but I would like to make sure the tool box can fit there with the light. From pics it looks like the light is sitting back from where the toolbox is mounted and it should be fine. Does anyone have this set up or would know if I close the toolbox will it hit the mounted light?
  8. Oct 25, 2015 at 6:44 AM
    #148
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Talk to @mattgecko and get yourself some of these!! Comes with full install instructions and it's super easy!!!!
    Arkie-Marty likes this.
  9. Oct 25, 2015 at 6:55 AM
    #149
    First.Taco
    First.Taco Active Member
    West Palm Beach, FL
    2015 Tacoma TRD 4x4 DCSB
  10. Oct 25, 2015 at 7:08 AM
    #150
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    submarined
  11. Oct 25, 2015 at 8:36 AM
    #151
    mrkabc
    Art
    Corona, CA
    Looks like from the pic of the toolbox (hard to tell) that they use the same mounting point on the bed. I don't think you'd be able to use the bed lights and the tool box. Looks to me like the LED strips might be a better option for you. (Installation wise, can't comment on durability. )
  12. Oct 25, 2015 at 9:43 AM
    #152
    bogginator
    Marsh
    Cherokee County
    You could always mount the lights at the other end of the bed.
    sandtaco2016 likes this.
  13. Oct 25, 2015 at 9:46 AM
    #153
    jk70
    Looks to me that the swingbox mounts to the section that juts out at the very back where that yellow sticker is (on the right) and the lights are forward of that section.
    I may do the lights on the other end or get the strip lights...still undecided
  14. Oct 29, 2015 at 6:06 PM
    #154
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    subed.. gotta see these great ideas in action... I'm gonna do 1 of them, I'm sure..
    Nice bunch of ideas... you guys rock..!!!!
  15. Nov 2, 2015 at 7:32 AM
    #155
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I just lamed out due to time constraints and wired it up to the dome wires by fuse box since I have a cover on back and won't be annoyed with the bed lighting up every time the door is opened. Dunno if has been mentioned but wiring it this way you can turn the dome light to off position but that doesn't keep the bed lights from still coming on. When I get the right switch and some free time, I will be wiring it up to either a switch in center console, back in the bed or both. I do like the lighting it provides back there in the "trunk" tho.
  16. Nov 7, 2015 at 9:13 PM
    #156
    andyr562
    andyr562 Well-Known Member
    Andy
    Long Beach Ca
    Did you end up buying this box?
  17. Nov 8, 2015 at 5:47 AM
    #157
    jk70
    I did but I recently had back surgery so limited in what I can do; therefore, I haven't attached it. After installing toolbox, if it looks like there would be room for these light I may install them.
    It's between these lights, or https://www.tacomaworld.com/threads/better-bed-lights.396909/ or another one that someone on here makes that are strip LEDS that go in the bed area, I forget his name
    Oops I see it above..@mattgecko
    moe2o4 likes this.
  18. Nov 8, 2015 at 7:00 AM
    #158
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    Did anyone else have these installed from factory??
  19. Nov 8, 2015 at 2:47 PM
    #159
    TrdPro14
    TrdPro14 Member
    2015 white Tacoma TRD Pro
    Installed mine yesterday, heres a night shot of them. They are pretty bright and held up well in the desert. I wired mine direct to the battery and put a switch on the inside of the passnger side cubby. I'll take better photos later
    THEPYRITETACO and adio like this.
  20. Nov 8, 2015 at 4:49 PM
    #160
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I can. Mine did not last a year. I replaced with some submersible 8" Shorelines. I like them more than the 5050s.
