New Tacoma With Towing Package - No Wires
Discussion in 'Towing' started by G23od, Feb 15, 2013.
  1. Feb 15, 2013 at 12:17 PM
    G23od
    G23od [OP] New Member
    Al
    Phoenix, AZ
    SR5
    I just got a 2005 Tacoma with the towing package. It has the OEM socket built in next to the hitch but did not come with the wires/adapter that goes from the tow socket to the trailer. Where can I pick one up aftermarket? The dealership tried to sell me the whole kit and kaboodle for $250.00 including an OEM socket even though I explained I just needed the wires/adapter.
    My apologies if the terminology isn't correct. Be gentle it's my first post.
  2. Feb 15, 2013 at 12:18 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    The wires that go from the socket on the truck to the trailer are part of the trailer's wiring harness. The truck's wiring ends at the socket and any wires from there would be part of the trailer. The only exception i can think of is if you have a 4-pin trailer. That would require a plug-in adapter to step down the truck's 7-pin socket to a 4-pin plug. That adapter can be found at any auto parts store or possibly Uhaul location.
  3. Feb 15, 2013 at 12:22 PM
    G23od
    Al
    Phoenix, AZ
    SR5
    So when I buy or rent a trailer it will come with the wires that plug in? For some reason I thought there was some wires or an adapter that came with the OEM socket...
    Nice looking truck by the way.
  4. Feb 15, 2013 at 12:26 PM
    Pugga
    Massachusetts
    F-150 Mod
    Yes, the truck's wiring ends at the plug and anything beyond that is part of the trailer's wiring.
    If you rent a trailer, it will likely be a flat 4 connector and you will need an adapter to connect to it. Your truck, having the factory tow package, has a 7-pin round socket so the adapter would be a 7 round to flat 4 adapter and will look similar to this:
    That would plug into your truck's round socket and the flat 4 connector from the trailer would plug into the part you see above. If you tow a trailer with a 7 round connector, no adapter is required. There are other wiring configurations but the 7 round and flat 4 are by far the most common.
  5. Feb 15, 2013 at 12:30 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Yep, what he said. The adapter is very inexpensive as well might as well just get one to have if you're going to be towing. My boat trailer is only a 4 pin so I need one.
  6. Feb 15, 2013 at 12:31 PM
    G23od
    Al
    Phoenix, AZ
    SR5
    Genius, glad I signed up here. Thanks for schooling me up. I guess I will pick up a 7 to 4 adapter to have just in case so I can work with any trailer.
  7. Feb 15, 2013 at 12:32 PM
    Pugga
    Massachusetts
    F-150 Mod
    :thumbsup:
    Welcome to TW by the way!
  8. Feb 15, 2013 at 5:41 PM
    PatSully
    PatSully Well-Known Member
    Pat
    Phoenix
    07 Access Cab TRD O/R
    Rear AAL, Extra D-Rings
    the plug that you may or may not have is the one that plugs in for the electric brake controller. if you trailer has electric brakes, you will need a controller and the small harness that goes between the truck's wiring harness and the controller.
    and that's if your trailer has electric brakes.
    edit, here the info you need if you are using trailer brakes.
    http://www.tacomaworld.com/forum/towing/4031-tacoma-towing-bible.html#post35022
