New TacomaBeast/OEMassive Headlights?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thisbechristian, Aug 11, 2021.
  1. Aug 13, 2021 at 5:46 PM
    #61
    AtomAnt
    AtomAnt Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    Can someone confirm for me if I have this right. The fuse tap for the Morimoto headlights is only used if your truck doesn’t have factory DRL, correct? So a truck with factory DRL would be simple plug and play with the factory headlight connections?
    wornandtorn likes this.
  2. Aug 13, 2021 at 6:23 PM
    #62
    wornandtorn
    wornandtorn Well-Known Member
    Nathan
    GA
    2020 Cement Tacoma TRD Sport 4x4
    Howdy - That’s exactly it. Factory DRL = 100% plug and play.
    For anyone without factory DRL, I can attest that the fuse tap was quick, painless, and otherwise easy even for a knucklehead like me.
    tclavell likes this.
  3. Aug 16, 2021 at 5:07 PM
    #63
    LuisLAN
    LuisLAN Well-Known Member
    Luis
    21 TRD OR DCSB
    - Bak Revolver X4 Tonneau Cover - Full Chrome delete
    Hello, apologies for hijacking the conversation, but, does the statement above apply to projector headlights too?
    Aftermarket headlights and using them with the OEM bulbs will produce poorer output?
  4. Aug 16, 2021 at 5:16 PM
    #64
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Most of the time yes. MOST aftermarket housings (honestly, probably all but I don't know of every example) use inferior lenses and projector buckets. You will get reduced output with even OEM bulbs.
    crashnburn80 likes this.
  5. Aug 16, 2021 at 5:40 PM
    #65
    LuisLAN
    Luis
    21 TRD OR DCSB
    Thanks for the quick answer. Is good to know that is mostly about the lenses, that makes sense.
    So, do you think that for an retrofit or BHLM project maybe it is a good option to go aftermarket since you probably will replace the lenses anyways?
  6. Aug 16, 2021 at 5:51 PM
    #66
    Abject4x4
    Abject4x4 Just another idiot on the internet
    Marcus
    White SR5 Access Cab
    I came here just to say that "TacomaBeast" is trash.
  7. Aug 16, 2021 at 6:54 PM
    #67
    Conclusion
    Conclusion Well-Known Member
    Canada
    DC TRD Sport with premium package and trail teams sport pacakge
    Sorry this has probably been beat to death as a topic but the lighting thread was massive and I couldn't find a clear answer.
    Up north we get screwed and can only get leds with a pro or nightshade trim. We all have standard daytime running leds though. If I wanted to swap to oem leds is this a simple plug and play or quite extensive? Thanks in advance.
  8. Aug 16, 2021 at 7:17 PM
    #68
    tclavell
    Troy
    Phoenix, AZ
    G70
    Easy swap but you’ll need a harness. Hit up @daveeasa
    Conclusion[QUOTED] likes this.
  9. Aug 16, 2021 at 9:00 PM
    #69
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    You will need a separate harness to connect the OEM LED headlights. I got mine from xrunnerdude who makes a great set. Now I think everyone gets it from @daveeasa
    Avoid TRS Harness, as it is a known issue that they blow fuses due to some wire being flipped.
  10. Aug 17, 2021 at 3:46 AM
    #70
    Conclusion
    Canada
    Thank you both for the replies, much appreciated!
