New Tail lights put in but running lights not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JakeL, Apr 26, 2020.
  1. Apr 26, 2020 at 7:27 PM
    JakeL
    JakeL [OP] New Member
    Hi Everyone,
    Today I installed a new set of tail lights on my 2005 Tacoma Prerunner, the tail lights were made by VIPMOTOZ and called Neon Tube LED. After installing them I checked if all the lights were working properly which they were but I didn’t have any running lights. Does anyone know a solution for this problem?
    Thanks,
    Jake
  2. Apr 26, 2020 at 7:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have you checked the 10A Tail Fuse?
    Do the Brake Lights work if you press the pedal?
    Do the License Plate Lights work?
  3. Apr 26, 2020 at 7:47 PM
    JakeL
    Brake lights are working when I pressed pedals same with license plate lights. Have not checked the 10A Tail Fuse. Thanks for the response
    TnShooter likes this.
  4. Apr 26, 2020 at 8:04 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If everything thing works On your oe light that you removed then the issue is in the new light somewhere.
  5. Apr 27, 2020 at 1:43 AM
    JohnT43
    JohnT43 Well-Known Member
    2007 Tacoma
    Radio
    I have the same lights, maybe reverse the plug.
