New timing belt now rough running engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by bigd489, Jan 3, 2024.
  1. Jan 3, 2024 at 6:50 PM
    bigd489
    bigd489 [OP] New Member
    Michael
    95 4x4tacoma
    95 Tacoma v6 3.4 ,300k plus noticed leaking water pump so we decided to do the new timing belt , water pump deal truck running fine at this point , we tare it down change all all timing marks lined up crank and both cams , idles great , but when u drop in gear starts running rough no power I’m at my wits end any help will be appreciated
  2. Jan 3, 2024 at 7:06 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    @Dm93 might have a clue. Good luck!
  3. Jan 3, 2024 at 7:13 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Did you double check the timing since you assembled it?
    Not uncommon to accidentally be 1 tooth off.
    ToyoTaco25 likes this.
  4. Jan 3, 2024 at 7:16 PM
    bigd489
    Michael
    95 4x4tacoma
    Yes I even loaded it on a trailer and took to local mechanic to look at it he confirmed timing is good
  5. Jan 3, 2024 at 7:18 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Was any other work done/parts removed when doing the timing belt and water pump?
    Any codes?
    Superdave1.0 likes this.
  6. Jan 3, 2024 at 7:26 PM
    bigd489
    Michael
    95 4x4tacoma
    No codes no other work it will idle great , but as soon as u drop in gear it just runs rough no power
  7. Jan 3, 2024 at 7:40 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Could be so many things. Did you take any in process photos, before and after photos? I'm a mechanic and take extra photos all the time. Just in case.
    Dm93 likes this.
  8. Jan 3, 2024 at 7:43 PM
    Superdave1.0
    SoCal
    Might have to make it run rough until it throws a code. Cam sensors plugged in? Crank sensor plugged in?
    What brand timing belt kit did you use?
    TACOTU3 likes this.
  9. Jan 4, 2024 at 2:16 AM
    457taco
    457taco Active Member
    Toby
    Brooklet, GA
    2001 Tacoma pre runner
    If it runs fine in park then your timing is good. I would look for vacuum leaks and or connectors not seated well. Also by chance did you clean the throttle body?
    Cloud99 and Steves104x4 like this.
  10. Jan 4, 2024 at 2:40 AM
    Aubrey
    Aubrey Member
    Provide some pictures to know the situation.
  11. Jan 4, 2024 at 3:32 AM
    Cloud99
    Cloud99 Well-Known Member
    Georgia
    1999 Tacoma SR5 TRD 4x4
    Agree with this. Sounds like a vacuum leak.
