New Tire Fitment Confirmation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Riley1015, Apr 20, 2025.
  1. Apr 20, 2025 at 11:02 PM
    Riley1015
    Riley1015 [OP] Active Member
    Riley
    2022 MGM TRD Sport
    Hi, I know there are millions of threads about tire sizes, but I cant seem to find one that specifically talks about the TRD sport wheels. I see that the general consensus is that the biggest tire size for the 17" wheels are 265/70/17. I found a really good deal on some 265/70/r17 tires, but everything I see on the forums talk about 0 offset. From my understanding, the wheels I have are +30 offset (2022 TRD Sport Wheels).
    Can someone please confirm that they should still fit okay with that offset. I'm 100% okay with trimming plastic or the mudflaps, just worried about needing a spacer for the UCAs.
    Also, I plan on lifting the truck 2" in the next couple of months.. don't know if that will have any impact on anything, but am needing new tires soon. The stock A30s are finally letting go at 70,000 Miles!:D
    Thanks in advance!
  2. Apr 20, 2025 at 11:27 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I wouldn't think they'd rub since the width on those is still a stock dimension. However 1" Bora or 1.25" Spidertrax wheel spacers will make your Sport wheels equivalent to approx +4 or -2 offset respectively for if you do go bigger tires / want a wider stance). Both brands are quality (avoid the no-name/unfamiliar-name ones that sell for cheap on Amazon/ebay)
  3. Apr 21, 2025 at 4:40 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    I ran them on my 18 sport with no rub. I did have just under 2" lift, but cleared UCA's. There are may that ran them on stock suspension and stock wheels.
  4. Apr 21, 2025 at 6:06 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Unfortunately changing the offset is the difference between rubbing or not rubbing. If you kept the oem rims, without a doubt they wouldn't have rubbed going to 265/70/17
