new tire question...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kiki111, Oct 15, 2020.
  1. Oct 15, 2020 at 5:18 PM
    kiki111
    kiki111 [OP] MENTALLY DISTURBED MEMBER
    Tacoma 2.7L SR
    so I'm reading a 255/80R17 is a 33...thanks i will do my homework
  2. Oct 15, 2020 at 5:19 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    This won’t help, but I’ve heard a 265/70 17 doesn’t rub but a 265/75 17 will. And your overall would be right between the 2 I think :thumbsup:
    But seriously, It wouldn’t rub much of it Does, and will be easy to mitigate
  3. Oct 15, 2020 at 5:20 PM
    kiki111
    Tacoma 2.7L SR
    and you have a 2" front lift?
  4. Oct 15, 2020 at 5:23 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    You aren’t listening to me. Lol
  5. Oct 15, 2020 at 5:25 PM
    gudujarlson
    Minnesota
    Yes. They are very to the same size. It’s just takes too much typing to include both the r16 and the r17 tall skinny 33 size.
  6. Oct 15, 2020 at 5:25 PM
    kiki111
    Tacoma 2.7L SR
    unless I overlooked it I didn't see where you said lift size...sorry
    ok...i read "stock size" thanks
  7. Oct 15, 2020 at 5:30 PM
    gudujarlson
    Minnesota
    Haha. I meant that lift doesn’t matter so stop worrying about it. I do have 2” in the front and rear last time I measured, but I don’t rub until hitting the bump stops or thereabouts and only when turning. A stock truck and my truck are close to identical when hitting the bump stops. I say close because I also have SPC UCAs that change my geometry a bit.
  8. Oct 15, 2020 at 5:44 PM
    gudujarlson
    Minnesota
    From all I’ve read on this forum, 255’s reliably don’t cause fitment issues and 285’s are really hit or miss depending on how carefully you drive your truck, how much rubbing you can tolerate, and other factors. People report problems with 285’s regardless of a 2-3” lift.
    I will admit though, if you are willing to drive your truck carefully enough to not use the full suspension travel Toyota gave it and/or you have a high tolerance for rubbing, a lift might help you be happy with your big tires. I personally do not drive my truck carefully or have a high tolerance for rubbing, so I will stick with my tall skinnies.
    2000prerunner23 likes this.
  9. Oct 15, 2020 at 5:48 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Or you do CMC and pinch weld. Also how did 285’s get brought into this, he’s asking about 255’s?
  10. Oct 15, 2020 at 5:51 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    This dude is all over the place. Ive attempted to reply more than i have but he keeps rambling about things.
    He says lifts dont help fit bigger tires and that you dont need a lift to fit 255's.
    But then goes on to say he is lifted b/c he doesnt want his 255's to rub?
    :duh:
  11. Oct 15, 2020 at 5:56 PM
    HighCountryTacoma
    Colorado
    Yeah I think he must be drinking. :rofl:
  12. Oct 15, 2020 at 6:05 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I should start a myth debunking debunking thread for some of these. Especially since almost all of them are blanket statements and don't apply to all applications.
    On topic with this response and this will be a little more technical than throwing around information with a I know mentality. Based on the offset of the new wheels I am guessing you went with an OE wheel???
    Your 2" level will be just fine to fit those tires you may have a slight rub (each truck is different) turned full lock in reverse on some of the plastics. But I know a few guys that have ran that size tire no lift or level they just trimmed the plastics.
    The biggest thing that will affect tire rubbing is rim width and offset(backspacing). The further you push the assembly away from the body 0 to - offsets the more arc it runs when steering and can potentially rub.
    So now lets address the rim width part we'll keep this simple so you can understand the math involved here. 2 wheels 0 offset one is 7" wide the other is 8". The 8" wide wheel has .5" more sticking out away from the body thus increasing that arc I was talking about in the offset part. Now to set them so they are pretty close to the same arc you'd get a +12 offset 8" wheel which would be the same amount of wheel from mounting surface to outside face as the 7" wide at 0 offset.
    You already decided to go the skinny tire route which is good for the same reasons that apply to the wheels as there is just a lot wider mass that is needed to clear.
    Adding a lift at static and normal street driving does help you clear bigger tires. It is true under full compression at certain angles the tires are turned you may run into clearance issues, again I know some guys that ran that tire stock and didn't really rub at full stuff.
    That's a little more in depth answer than you've been getting. If you have any other questions I'd be glad to answer them and actually show you with calculations. Again I'm going to reiterate that every truck is different and some will rub and some won't, but with what you have you should be minimal. Go for it if you want to it's your truck and you know how you are going to use it and what you want out of it.
  13. Oct 15, 2020 at 6:06 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Check out this video, has some good stuff
    https://overlandoutfitters.ca/blogs/news/the-myths-of-lifting-an-ifs-vehicle
    ovrlndkull likes this.
  14. Oct 15, 2020 at 6:09 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Don't worry 2nd gen guy will save the day I know sometimes you need help :rofl:
  15. Oct 15, 2020 at 6:11 PM
    #35
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    :popcorn::popcorn::popcorn:
  16. Oct 15, 2020 at 6:18 PM
    #36
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    See my tech heavy post above
  17. Oct 15, 2020 at 6:21 PM
    #37
    kiki111
    Tacoma 2.7L SR
    thanks to all.... some of you guys made me laugh...it's simple for me before I spend $800 plus dollars on new tires I want to make sure that's all.... spent enough money on upgrades, lifts, new alloy wheels on the way. before I swap out the tires also.... once again thanks for all...
  18. Oct 15, 2020 at 6:24 PM
    #38
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    Correct , I’ve been trying to tell these handicaps this for ages now.
    Im actually amazed someone was able to point this out on TW.
  19. Oct 15, 2020 at 6:24 PM
    #39
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Skips reply was the best in the thread. Mine included.
    Good luck OP
  20. Oct 15, 2020 at 6:57 PM
    #40
    gudujarlson
    Minnesota
    Why wouldn’t I be? :)
