New tire, safe to run with my nearly worn out tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by manfred twd, Aug 1, 2024.
  1. Aug 1, 2024 at 7:01 PM
    manfred twd
    manfred twd [OP] Active Member
    mike
    2021 trd takoma
    I'm about ready for new tires and have been doing my research.
    That said I ran over an object in the road and had to buy another tire. Spare says temporary use only.
    The tire I bought is the same brand but has lots more thread as it is new.
    Now I'm starting to worry if this will cause damage due to the larger diameter of the new tire.
    am I safe to run on it until I decide what new tires to buy?
  2. Aug 1, 2024 at 7:02 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    I’d run it while whatever else is on order personally.
  3. Aug 1, 2024 at 7:06 PM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Simple, put it on the front axle and don't engage 4WD until you replace all four tires. Problem solved.
    akimmel, CVCV, boston23 and 8 others like this.
  4. Aug 1, 2024 at 7:35 PM
    Trail Limo
    Trail Limo Well-Known Member
    This is the way.
  5. Aug 1, 2024 at 10:51 PM
    lessgoo88
    lessgoo88 Well-Known Member
    2019 Tacoma TRD Off-Road Cav Blue
    King 2.5 Coilovers, Cab Mount Chop, 33’s, Lights.
    You shouldn't run into much issue only issue I had was that it pulled in the direction of the new tire. I thought it was an alignment issue at first
  6. Aug 2, 2024 at 7:34 AM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    Yes, this needs to be restated firmly. A difference in wheel diameter from front to back will lock up your 4wd for sure.
    saltybum likes this.
  7. Aug 2, 2024 at 7:53 AM
    Clearwater Bill
    Billy
    Largo Florida
    Isn't the spare a full size?
    Taco22trdor likes this.
  8. Aug 2, 2024 at 7:54 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You have a TRD OR and the spare says temporary use only? Aside from the absence of a TPMS sensor, that spare tire should be the same model as the other four.
    But yes it's safe to run a new tire mixed with three worn ones. There's less difference in new vs old tread depth than in sidewall compression from the different weights front and rear.
  9. Aug 2, 2024 at 7:58 AM
    blind cowboy
    blind cowboy Well-Known Member
    Don
    Auburn CA
    2002 TRD XC 5sp
    When you buy new tires consider getting 5 of the the same and using the spare in your tire rotations. Eliminates that problem if you lose one plus you get about 20% more miles out of a set.
    musicisevil likes this.
  10. Aug 2, 2024 at 8:22 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Get rid of the piece of shit temporary spare tire and replace it with the new tire you recently bought. Then buy a set of 4 new tires to replace the the old worn ones.
    Problem solved. Simple, easy peasy
    saltybum, akimmel, soundman98 and 3 others like this.
  11. Aug 2, 2024 at 8:29 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Let me share my Costco tire story. About 15 years ago I had Bridgestone tires on a RAV4. Got a nail near the outer edge of the tread, Costco said it was too close to the sidewall wall to patch. Costco also told me at that time they were not currently carrying Bridgestone. The Costco tire guy said he would “road-hazard” the tire with the nail and refund me on the other 3 good Bridgestone tires which had 50% tread left. Four new BF Goodrich tires cost me about $80 dollars. This is why I buy all my tires from Costco.
  12. Aug 2, 2024 at 11:56 AM
    Sprig
    Ken
    I’m a Costco member and shop there all the time. I’ve never bought tires there cause they don’t carry the brand I like, I wish they did. But the most incredible thing about buying tires there is that all the tires they sell have a 5 year road hazard warranty. You screw up one of their tires they will repair it or replace if bought within 5 years. And they have incredibly good prices on their tires.
    MGMDesertTaco likes this.
  13. Aug 2, 2024 at 12:00 PM
    Aspiringhobo
    Aspiringhobo Member
    ‘23 Taco TRD O/R with that Alu-Can Canopy
    Why does this happen?
  14. Aug 2, 2024 at 12:05 PM
    MGMDesertTaco
    I've heard (if one tire has more tread) a wear pattern issue can develop on the gears if placed on the rear axle. You should be fine temporarily though. The issue with the full size spare listed as temp use only, has to do with the lug nut style and the spare rim. The lugs will have a tendency to losen over time if installed for full time use.
    There was a thread somewhere explaining the different lug nut type needed if one wanted to use the spare wheel full time. See here...
    https://www.tacomaworld.com/threads/lug-nuts-for-spare-steel-wheel.805772/#post-28891376
  15. Aug 2, 2024 at 12:32 PM
    Sprig
    Ken
    The only time this is a concern is on All Wheel Drive vehicles and 4WD vehicles when in 4WD. Generally tire shops will not replace a tire on these vehicles if there is more than 3/32 between a new tire and the tires on the vehicle.
    Bottom line is if you need new tires just get the damn things, a set of 4. Stop trying to overthink this . Your life and others lives depend on your tires. Get a new set of 4 today and move the newest and best current tire to the spare. Get rid of that temporary piece of shit tire. Enough said.
  16. Aug 2, 2024 at 12:34 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Interesting news there. I thought being a full-size spare made it "not temporary" like the doughnuts (if even doughnuts) in passenger vehicles. How safe is just buying lugs designed for the spare rim? Or is the steelie-spare rim just not up to full-time load? I am considering buying a basic-but-full-time rim for the spare from Discount.
  17. Aug 2, 2024 at 12:35 PM
    RichochetRabbit
    Discount Tire and most any other tire shop offers that unpleasant-but-works 90-day financing to help if the OP just needed a couple more months to save up.
    Pwakchop likes this.
  18. Aug 2, 2024 at 12:41 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    yes but they put a 'temporary use only' sticker on it
  19. Aug 2, 2024 at 12:42 PM
    RIX TUX
    what happens to the TPMS?
  20. Aug 2, 2024 at 12:44 PM
    RIX TUX
    it isnt a temporary tire
    Sprig[QUOTED] likes this.
