new tire size for new wheels
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4421.frank, Jan 19, 2010.
  1. Jan 19, 2010 at 4:08 PM
    4421.frank
    4421.frank [OP] Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    what tire siz can I go with if I get 16" pro comp steel rims while avoiding rubbing issues.
    The truck has bilsteins on the front set at 2.5" in the front and bilsteins with a toytec 1.5"AAL in the rear
    would like to have the tires reach the outside edge of the fenders.
    thanks for your input
  2. Jan 19, 2010 at 4:11 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    get 16x8 or 16x9 and 265/75/16
  3. Jan 19, 2010 at 4:14 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    16x8 with 4" backspace wrapped with 265-75-16s will look balanced on a doublecab...
  4. Jan 19, 2010 at 4:29 PM
    kinkrider101
    santa barbara
    wheels and tires
    how much do you want it to stick out?
  5. Jan 19, 2010 at 4:30 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    yep 265/75/16 would fit good, thats about a 32'', 31.6 i believe
  6. Jan 19, 2010 at 7:21 PM
    4421.frank
    Southside chicago
    not at all. Just about flush with the wheel well trim. It has stock 16" rims now as well as 265 tires. Although the tires are over two years old :eek: what does the other number identify (i.e. 16x8 or 16x9), the width? I got the bf all weather tires now but what would be compariable set of new all weather tires?
  7. Jan 20, 2010 at 4:16 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    the 8 or the 9 is the width yes
  8. Jan 21, 2010 at 10:35 AM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    i have a 2004 double cab and the 265 75 16 rub up front not much but they hit on the inner fender well. nothing a little heat and melting the fender wont fix
  9. Jan 21, 2010 at 11:01 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    Heres what a 265/75/16 looks like on a Procomp 16x8 BS-4 wheel.
  10. Jan 21, 2010 at 11:21 AM
    4421.frank
    Southside chicago
    thank you sir
    that is exactly what I needed to see. the same rims I would like to buy and tires as well. Are those the steel rims? Or the $ alloys $ ? What tirtes you go with?
  11. Jan 21, 2010 at 11:28 AM
    PrezidentRedz
    Redz
    Owings, MD
    the Alloys, I got them from WheelersOffroad.com and the Tire is a Nitto Dura Grappler. I got those from NTW.com
  12. Jan 21, 2010 at 4:07 PM
    4421.frank
    Southside chicago
    I don't need any back spacers for that profile, do I?
  13. Jan 21, 2010 at 5:25 PM
    PrezidentRedz
    Redz
    Owings, MD
    Huh?
  14. Jan 21, 2010 at 5:58 PM
    s2kvtak
    s2kvtak Well-Known Member
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    Grillecraft grill w/ TRD badge, Bilstein 5100s on all 4 corners set at 2.5" and Toytec AAL in the rear. 285/75-17 Interco TRXUS M/T
    what is NTW.com? i tried to pull it up and got nothing
  15. Jan 21, 2010 at 6:50 PM
    PrezidentRedz
    Redz
    Owings, MD
    my bad. heres the link..
    http://www.ntwonline.com/
  16. Jan 22, 2010 at 6:18 PM
    4421.frank
    Southside chicago
    is the bolt pattern for the rims 6 on 4.5 or 6 on 135? checking out the pro comp website now. looking to purchase before the end of the weekend. goin with the steel rims, the alloys are a little to pricey.
  17. Jan 22, 2010 at 6:29 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
  18. Jan 22, 2010 at 6:35 PM
    4421.frank
    Southside chicago
    thanks mikesdoublecab
    gonna order 'em in a day or two pro comp series 8069 16" wheels witha 6 x 5.5 bolt pattern. Now I got to find a decent all weather tire to put on 'em ( any suggestions?) i was thinking maybe a 285 tire as opposed to a 265 tire. Shouldn't be a problem, right? There is considerable room because of the lift on the front and back.
  19. Jan 22, 2010 at 6:48 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    how much are you getting them for?
    wheelers offroad sells the same wheels and since they are a vendor here on TW, maybe they have a member discount...
    do some comparison shopping between them and 4wheelparts...
  20. Jan 23, 2010 at 8:08 AM
    PrezidentRedz
    Redz
    Owings, MD
    I would stick with the 265/75/16, You will get great MPGs, besides if you go 285 its going to be taller than the 265.
    check this, this will help you understand the Metric sizes. http://www.miata.net/garage/tirecalc.html
