New tires and a few questions around this fitment.
Discussion in '1st Gen. Tacomas (1995-2004)' started by DKbik3r, Oct 30, 2023.
  1. Oct 30, 2023 at 7:19 PM
    DKbik3r
    DKbik3r [OP] Well-Known Member
    Daniel
    Springfield MO
    1st Gen Taco/3rd Gen 4Runner
    I got new tires put on my 1st gen,(285 75 16) im pretty sure I have a 2.5 lift and leveling kit but I put it on around 10 years ago so I can't remember. Now my question is I don't rub anywhere on flat ground, I'm pretty certain I'm going to rub when I flex the suspension, is it time for a new lift to reduce that? The tires looked semi tucked into the fenders compared to my previous tires. I guess I won't know till I take it offroad but it would be nice to figure things out before I take some chunks out of my new tires. If there's anything else you recommend let me know, I'm new to bigger tires.
  2. Oct 30, 2023 at 11:00 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What size were the old tires?
    The wheels are what determine how far "tucked in" the tires are. Did you put your new tires onto new wheels?
  3. Oct 30, 2023 at 11:02 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Either bump uptravel, cut, or go to a smaller tire
  4. Oct 31, 2023 at 12:43 AM
    DKbik3r
    Daniel
    Springfield MO
    No they are the stick wheels.
    Idk what ill have to cut yet. I need to get the time to pull the truck in the garage and check to see what itll hit at full flex.
  5. Oct 31, 2023 at 1:10 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Remove your coilovers and cycle the suspension full bump and full lock left and right.
    Kevins60 likes this.
  6. Oct 31, 2023 at 1:40 AM
    DKbik3r
    Daniel
    Springfield MO
    Sweet I will do that this weekend!
