New tires and new pull to the right
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CBrob, Dec 30, 2023.
  1. Dec 30, 2023 at 5:36 PM
    CBrob
    CBrob [OP] Well-Known Member
    Rob
    stock 2003 and stock SR 2020
    not a single mod
    Just installed some 285/75 wild peaks on the Tacoma.
    Noticed a pull to the right anytime it's in 4wd that wasn't there right before the tires.
    I'm in snow country so drive in 4wd often.
    I think I'll try swapping the front tires left/ right and see if there is any change.
    Anyone else experienced this?
    RIX TUX and 9pm like this.
  2. Dec 30, 2023 at 5:37 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Rotate the fronts side to side and see if anything changes
    MannyS and CBrob[OP] like this.
  3. Dec 30, 2023 at 5:47 PM
    Sasquatchian
    Sasquatchian Well-Known Member
    It could be a weirs tire but it could also be related to alignment or both. Did you get it aligned?
  4. Dec 30, 2023 at 6:02 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    did you check your tire pressures?
    CBrob[OP], BMH and na8rboy like this.
  5. Dec 30, 2023 at 7:19 PM
    CBrob
    Rob
    not a single mod
    Not yet, will check
  6. Dec 30, 2023 at 7:20 PM
    CBrob
    Rob
    not a single mod
    No alignment, just a slightly bigger falcon.
    Only noticed in 4d , tracks great in 2wd
  7. Dec 31, 2023 at 12:59 AM
    chasecmc
    chasecmc Well-Known Member
    Chase
    2017 DCSB TRD OR
    GFC Bilstein 6112/5160 Icon RXT Rock Sliders
    If you go to a bigger tire and want it to last I’d recommend at least getting the alignment checked.
    Chew likes this.
  8. Dec 31, 2023 at 6:48 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Maybe an alignment, but did you get a "road force" tire balance? I did that with my Duratracs and then with my Wildpeaks, both times I upsized.
  9. Dec 31, 2023 at 6:53 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    the size of the tire has nothing to do with alignment. the alignment is the same with no wheel even on the truck as it is with a 35” tire
    CBrob[OP] and soundman98 like this.
  10. Dec 31, 2023 at 7:07 AM
    soundman98
    NW Indiana
    it's also extremely odd that this happens after a tire change. other than tire pressure, tire changes will have absolutely no influence on the alignment of a vehicle.
    it's entirely possible the tire change made the OP more sensitive to his truck, and his alignments been out of whack for a long time, but it makes zero sense that changing rubber would alter suspension components.
    my old ranger was extremely sensitive to tire pressure alterations. a 3-5 psi variation side to side, or in the front tires altered it's handling dramatically
  11. Dec 31, 2023 at 8:15 AM
    chasecmc
    Chase
    2017 DCSB TRD OR
    Hmm, this is what a quick Google search shows. May not be a huge difference in the alignment but when you buy new tires it’s a good time to check the alignment. Especially if you have a pulling issue.
  12. Dec 31, 2023 at 8:49 AM
    soundman98
    NW Indiana
    i would like to see the documentation of this. most alignment rigs work by attaching to the metal wheel rim, not the rubber. so rubber condition/size/flex should have zero effect on alignment.
  13. Dec 31, 2023 at 9:15 AM
    smithlaketaco
    smithlaketaco Well-Known Member
    Houston, Al
    95 TRD OR,2002 TRD OR,2020 AG PRO ALL MT
    It has to be true it' on the internet.........
    soundman98 likes this.
  14. Dec 31, 2023 at 9:29 AM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    It’s a truck and large off road tires won’t be perfect for ride and balance might not always feel right. Going off road will tweak it even more. Even brief hunting trips throw things off. Shouldn’t pull right or left. Check pressure and alignment and call it close enough.
    CBrob[OP] likes this.
  15. Dec 31, 2023 at 9:33 AM
    Rogue4
    Rogue4 Member
    PNW
    21 TRD O/R DCSB
    Could be a radial pull from the tires. Even if the alignment was in spec, if the steel belts inside the tires aren’t even they can cause a pull.
  16. Dec 31, 2023 at 11:08 AM
    CBrob
    Rob
    not a single mod
    Embarrassing how simple this was....
    It was low on air leaving the tire shop.
    I think it must have been leaking around the bead and stopped after driving some.
    It was 15 psi...
    Bishop84, soundman98, BMH and 2 others like this.
  17. Dec 31, 2023 at 11:39 AM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    Yeah, you need to double check the tire shop guys. I put all new tires on my truck a couple months ago. Drove it home and checked the PSI the next morning. They were anywhere from 28 to 32 PSI.
  18. Dec 31, 2023 at 12:51 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Another example of double checking the work that a shop does. Everything from tire pressures and wheel torque when tire or brake work done to oil level after oil change and anything else shop said they "checked". People in shops don't care about your vehicle like you do and are often not trained well or checked on. They just do jobs as quickly as they can and cut corners. I know first hand as I was in trucking and tire business.
    CBrob[QUOTED][OP], soundman98 and BMH like this.
  19. Dec 31, 2023 at 2:48 PM
    BMH
    Bruce
    Soooo true!
  20. Dec 31, 2023 at 3:06 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Another Festivus miracle!
