New tires and rims...need advise!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TNTacoma2012, Apr 11, 2012.
  1. Apr 11, 2012 at 7:45 PM
    TNTacoma2012
    TNTacoma2012 [OP] Active Member
    Soddy Daisy
    2012 Double Cab Tacoma TRD Offroad 4x4
    17x9 XD Addicts rims with 265/70 R17 Nitto Trail Grappler M/T's. Bilstein 5100's front, ToyTec add-a-leaf rear. 15-16mpg! :-(
    Hey all...a newbie here...
    I have a 2012 4 door, short bed, Tacoma TRD 4x4. Stock tires are 265/75 R16 (~31"x 9.5). I want to increase the size of my meats and replace the rims with something black. I was considering a 285/75 R16 (~32.8" x 11.4) or 33"x12.50 R15. Sitting these new tires up next to the stock tires on the truck, the new tires look huge. NTB and Firestone seem to think a 15" rim wont fit on the new TRD because they will rub the brake rotor and/or drums.
    Stock, the truck sits approximately 2" lower in the front than the rear. My Toyota dealer told me that SkyJacker sells a 3" longer front strut that uses the OEM spring to raise the front 3" with a 1" rear axle block to level the truck and give me a small lift without affecting ride or handling, and seems to think it would accomodate ~33" without a problem.
    All that being said, has anyone gone as large as a 285/75 or 33x12.50? This truck is going to be used 90/10 onroad vs off, but want a meaner, wider stance, but dont want spacers or these wimpy BF Goodrich AT's.
    Then comes in the whole question of what backspace/offset do I need to run something this size.
    Any/all advise is welcome!
    Thanks!
  2. Apr 11, 2012 at 7:56 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    1. DO NOT USE BLOCKS IN THE BACK! very bad. and they ride like shit! get a add a leave or something. and also you are going to need 3” of lift to fit that tire. and 15” rims will not fit on 2nd gen TRD’S OR SR5 that have the 6 lugs.
  3. Apr 11, 2012 at 9:13 PM
    TNTacoma2012
    Soddy Daisy
    Ok, duely noted...so does anyone have a recommendation of what lift to go with. What application is best? Not wanting to break the bank, but looking for advise to lift CORECTLY and increase the tire size without overly affecting the current ride. If the tires are to large, what would everyone recommend. Rim size is still open...so ALL recommendations are welcome! This is my DD, my only vehicle and plan to keep it long term. Doing this right is 1st priority.
    I saw a thread about complaing to Toyota Corp about a bottoming out issue with the 3 leaf set up and the expected replacement of the 4 leaf. Is this a valid replacement from Toyota?
  4. Apr 11, 2012 at 9:24 PM
    ONEOFMANY503
    ONEOFMANY503 Well-Known Member
    Portland, OR
    2010 PreRunner DCSB SR5
    5100 front at 2.5'', rear leaf tsb and 1.5'' AAL, tinted tails,Race Line Raptors 16x8, Wild Country XTX with mountain snowflake 285 75 16, tow hitch w/brake harness, locks on storage bedsides, tailgate theft mod, heather blower tsb, custom bed rails, black front valance, mud flap delete, 12v full time power, seatbelt buzzer silenced, custom storage behind rear seat, bottom of cab painted, rear view mirror on/off switch, diff breather relocation,
    Get some bilstein 5100's for the front and set them at 2.5 and have the tsb done.I also added an add a leaf on that so i could still have some rake. Total of 5 leafs. You can fit 285's with 2.5'' lift but you have trim a lil' bit. Definately get a 16'' wheel with 4.5'' backspacing if you can.
  5. Apr 11, 2012 at 11:02 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    i agree. 16” maybe 17” if you can’t find what you like in a 16” i would not go bigger than 17” unless you have 6” lift. IMHO. at least with off road tires.
  6. Oct 8, 2013 at 10:07 AM
    CATwrencher
    CATwrencher Member
    James
    Louisiana
    2011 TRD off-road dc sb
    Either of you guys think a 33-11.50 -16 will work on a 2011 dcsb with the billies set at 1.75 and the tsb?
  7. Oct 8, 2013 at 10:09 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    5100's to level out 5100's 884 coils and an add a leaf (if your not planning on running a plate bumper or anything heavy on the front) for a 3" and 285 fit fine. 15" wheels are too small and will rub
  8. Oct 9, 2013 at 9:40 AM
    CATwrencher
    CATwrencher Member
    James
    Louisiana
    Your referring to the factory coil on a TRD as an 884?
