New tires and Slip Indicator light
Discussion in 'Wheels & Tires' started by Tinman49, Aug 4, 2014.
  1. Aug 4, 2014 at 6:24 PM
    Tinman49
    Tinman49 [OP] New Member
    Bruce
    Massachusetts
    Tacoma 2WD
    16"x7" rims and tires.
    Just bought a 2014 2wd Tacoma and new to the forum. Looks like a lot of savvy tacoma owners here. I'm not, so have a question. I didn't like the stock steel rims so wanted alloy ones. Wanted bigger also as 15's just look too small. So had 16"x7" rims and tires installed. Tire store wanted to recheck torque on lug nuts after 25 miles. After they did that I noticed the Slip Indicator light was on and it won't go off. They said nothing they did would make the light come on. I can't see a reason for it either. Bringing it to dealer to see if they can figure it out. Just wanted to know if anyone here knows if new tire size or something the tire store did could have caused the light to come on.
  2. Aug 4, 2014 at 6:41 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    With 4x4 models, there have been cases where a 3" lift causes the VSC light to come on. Haven't heard it happen with the 5-lug models. What size are your new tires? They are the same size at all four corners, right?
    It is also rare, but possible, for the installer to accidentally bump a wheel speed sensor cable when putting on the new wheels. Are the other lights like ABS also coming on?
  3. Aug 4, 2014 at 6:44 PM
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    I love your knowledge and your sig pic. :D
  4. Aug 4, 2014 at 6:59 PM
    Tinman49
    Bruce
    Massachusetts
    Tacoma 2WD
    New tires are 235/70R16S. No other lights on but because of the timing of the light coming on it could be possible installer did hit something. Just don't see that happening by tightening lug nuts but..?? Is the Slip Indicator light related to the VSC light?
  5. Aug 4, 2014 at 7:23 PM
    KenLyns
    Belly of the Beast
    I think we are referring to the same light.
    If ABS light isn't on, it in fact may not be a damaged wheel sensor cable.
