new tires and won’t fit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlakeDylan, Dec 10, 2024.
  1. Dec 10, 2024 at 5:09 PM
    BlakeDylan
    BlakeDylan [OP] New Member
    2008 Toyota Tacoma 4Dr TRD
    I just recently bought some 33 12.50 17R nitto mud grapps to put on my truck. I already have the 3” leveling puck on there and I can’t turn more than 1/2 way without tearing my fender off. Should I try to install a 3.5” loaded strut or just cut and trim with the puck on there ? (I have a 1 inch spacer to clear control arms)
  2. Dec 10, 2024 at 5:25 PM
    Greyhome
    Greyhome Well-Known Member
    Graham
    Richmond, VA
    2015 4Runner Trail
  3. Dec 10, 2024 at 5:26 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Get to cutting. CMC will need to be done. If you dont have after markets ucas probably should go ahead and get those. Probably need beat down the pinch welds if you really want to run a 33/1250. What wheels are you running? Width and offset?
  4. Dec 10, 2024 at 5:27 PM
    gotoman1969
  5. Dec 10, 2024 at 5:29 PM
    BlakeDylan
    17in 4 runner stocks
  6. Dec 10, 2024 at 5:30 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Lift won't help :sawzall:
    SethM and essjay like this.
  7. Dec 10, 2024 at 5:42 PM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    watch that video and then decide cab mount chop and pinch weld flattening with those tires..a "lift" doesnt give you more wheel well clearance, its just the way Tacomas are built
    Edit: Oh I just noticed you have a wheel spacer as well, which will actuall push the tires FURTHER in to the wheel well on turns...
  8. Dec 10, 2024 at 5:51 PM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    Need more offset wheel
