New Tires causing tire sensor problems
Discussion in 'New Members' started by dkhalil, Nov 3, 2020.
  1. Nov 3, 2020 at 5:21 AM
    dkhalil
    dkhalil [OP] New Member
    2014 Toyota Tacoma Prerunner double cab
    New Hancook Tires JUNE 2020
    Hi everyone I wanted to know if it is dangerous to drive this truck with the tire sensor light on.I just put new Hancook tires on my 2014 Toyota Tacoma Prerunner in June. Then I took the truck for trip from SC to Maryland. No problem. Then half way home the tire sensor light starts blinking then turning solid every time I stopped and started the car. I called Toyota told them they said sensor not connecting to some system. It still blinks then goes solid every time I drive it.
  2. Nov 3, 2020 at 5:36 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    A tire pressure gauge will tell if it's safe to drive. Sometimes you just have to go old school.
    buckhuntin-tacoma likes this.
  3. Nov 3, 2020 at 5:58 AM
    dkhalil
    How much pressure. The tag on door says 30 psi but they run hard at that rate so I inflated them to 33 they feel a little better but still feels bumpy.
  4. Nov 3, 2020 at 7:24 AM
    Black DOG Lila
    Virginia
    Overpressure = rough ride and uneven wear. I run recommend PSI on roads.
    Drop to 12 PSI on sand.
  5. Nov 3, 2020 at 7:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not if the tires are all the correct pressure. The light can tell you when you have a tire problem, or it can be a false positive if the system has a problem.
    Inflating them more makes them harder. Drop to 30 and perform a chalk test, adjust (if needed) 1 lb at a time till test is passed. Google 'chalk test treadwear' for a how to
    Your sensors are 7 model years old, and 6-7 real years old. About time for the batteries to fail. New sensors at the time of install would have been practical.
    However, as said, maintain your tires manually as was done for decades and ignore the light till you are ready to deal with it.
  6. Nov 3, 2020 at 7:46 AM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Blinking tire light that then goes solid usually means a bad sensor
  7. Nov 3, 2020 at 9:45 AM
    dkhalil
    Thank you everyone I appreciate your advice and I feel more comfortable with this light problem.
    T-yoda likes this.
  8. Nov 3, 2020 at 11:41 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  9. Nov 3, 2020 at 11:48 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If I were buying new tires for a 7 year old truck I'd have bought new sensors beforehand and had them installed with the tires. Most any shop won't charge any extra at that time. To do it later will usually run $15-$20 per tire to install them. You can pick up new ones on Amazon for $20-$25 each.
    Normal life span is 6-7 years, but 10 years isn't unusual. My 13 year old truck still has working sensors, but I know they will fail any day now.
  10. Nov 5, 2020 at 4:49 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
