New tires for 4x4
Discussion in 'Wheels & Tires' started by TacoinSC, May 16, 2008.
  1. May 16, 2008 at 8:50 PM
    TacoinSC
    TacoinSC [OP] I'd rather be in Jamaica...
    Greenville, SC
    2011 A.C. 4x4 TRD Off Road
    Undercover
    Okay, I have a 08 reg cab 4x4 with the standard equipment Dunlop Grandtrek AT20's.
    Whose bright idea was it to put highway tires on a 4x4? I understand my base model truck probably has a lower profit margin than a loaded out double cab and the highway tires contribute to better fuel economy over all terrains,
    but still. I haven't had my truck long enough to try out the 4WD (Quiet! I can't type with all of this booing!) but the factory tires look like they would have trouble with anything tougher than wet grass.
    So, I need some input for alternative choices. I must admit I'm leaning towards BFG AT KO's, but I want to run the stock size and apparently they
    only come in load range E (!!!). I love the way they look, but I think 10 ply
    is a bit overkill for my needs.
    Should I just go ahead and put 1 ton truck tires on my truck or should I find something else? I know appearance is subjective, but I love the 'classic' BFG AT look.
  2. May 16, 2008 at 9:52 PM
    tex
    tex Well-Known Member
    Fort Worth, TX
    2006 V8 Sport 4Runner
    I have a single cab prerunner and I am looking for some new tires for the wheels I am ordering next week. I am looking at a 265/70/16. They are a little wider and just a hair taller.
    I have looked at the Toyo open country AT and the Kumho road venture AT. I had the Kumho on my Nissan Titan and they were very good tires. I too would like the BFG but they are a little too much for me.
  3. May 17, 2008 at 5:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I used to run BFG A/T's exclusively. One day I was offered a new set of Nitto Terra Grapplers to try out. I have been running them on all my trucks since. They offer more grip in all terrain and conditions than the BFG's, I have found. :)
  4. May 18, 2008 at 8:32 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    When it's time to replace my BFG rugged trails it won't be the BFG T/A KO's after reading the reviews on "Tirerack" and "Discount Tire". It will be what I had on the last truck being the Michellin LTX M/S.
    Better mileage with less care and plenty aggressive for what I do off road. Easily a 60,000 mile tire and great on pavement. Not to mention less $.
  5. May 18, 2008 at 8:36 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i really like my bridgestone dueler a/t revos in 265/70/16...stock size. great on and off road, balance real well, wear good and even, and they are smooth on the highway.
  6. May 18, 2008 at 8:46 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    bfg at ko's are nice but if youre worried about your fuel mileage dont bother, theyre rather heavy tires IMO.
  7. May 18, 2008 at 8:55 PM
    jtruck618
    jtruck618 Member
    Yep, that At's are very heavy compared to most other tires. I think you can find tire weights on discountire or tirerack.
  8. May 19, 2008 at 5:45 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Dont feel bad my $27k truck came with the same shitty tires you have. I am going to drive them bald then replace them with either BFG all-terrains or Bridgestone duelers.
  9. May 19, 2008 at 12:15 PM
    TacoinSC
    Greenville, SC
    Undercover
    I just came back from the tire shop. I went with the Bridgestone Dueler A/T Revos. They had them in my size (245/75/16) in P-metric, cause I don't really need load range E tires. I got them for $119 each, plus $100 mail-in rebate, so I think I did alright.
    Thanks for your help!
  10. May 19, 2008 at 2:12 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you'll like them.....awesome tires man!!
  11. May 21, 2008 at 5:14 AM
    p38
    p38 Member
    I just picked up my new 2008 4 Clyindar access, 4x4, 5 speed and looking to put AT tires on it. Were can I find the best deal fo a good tire that wont break the bank?
  12. May 21, 2008 at 2:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if you are looking online....check out tirerack.com, other than online, see what discount tire or costco/sams has. good deals with all of them really.
  13. May 21, 2008 at 3:22 PM
    TacoinSC
    Greenville, SC
    Undercover
    Bridgestone still has a $100 rebate on the Dueler A/T Revo for purchases through June 10th.
    http://www.coupons-coupon-codes.com/tire-rack/#tire-rack-deals
  14. May 28, 2008 at 5:42 AM
    p38
    p38 Member
    tacomaman06,
    were did you get your fog lights?
  15. May 28, 2008 at 1:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the actual fog lights on the truck or the lights on my bull bar???
    the ones on my truck came stock on the truck......the lights on my bull bar are actually long range hella 500 driving lights, and i got those at pepboys for right around $70. i also got the grille type covers for them there too.....$20 for the set of covers.
  16. May 28, 2008 at 4:07 PM
    p38
    p38 Member
    I wish my tacoma 2008 came with those lights stock, I'm having a hell of a time finding true fog lamps to mount in the stock bumper sockets and Toyota wants a mint to put them in.
  17. May 28, 2008 at 5:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I the OME 885 springs with OME shocks and TC UCA's. On the back I have a custom made 1" AAL with the TSB leaf packs. 5100 Bilstiens to control the bounce.
    Tire size is 285/60/18.:)
  18. Jun 5, 2008 at 3:38 PM
    Revern
    Revern Member
    I put Pirelli Scorpion ATR's on my 07 double cab today. Very nice looking tire, performance has yet to be determined.
  19. Jun 5, 2008 at 3:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i have heard nothing but good comments about the scorpion atr's. plus, they look alot like the revo's that i have, with almost the same type of tread pattern, but they are alot less. seem like an awesome tire. let us know how they balance out, and how the ride/performance is with them.:)
  20. Jun 5, 2008 at 3:49 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    How does one go about getting a custom made AAL? I wonder if Alcan can custom make me one to go with my tsb leafs...
    After I'm lifted 3", I will be running 265/75/16 BFG M/Ts on my TRD Alloys.
