new tires for my 1st gen pre runner
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04prerunner, Sep 2, 2010.
  1. Sep 2, 2010 at 5:07 PM
    04prerunner
    04prerunner [OP] Well-Known Member
    kyle
    tampa, Fl
    2004 prerunner
    stock
    getting new tires for my 1st gen dcab prerunner
    so im pretty sure 265/75/16 is as big as i can go with no lift but what is the exact size of 265/75/16 !!!!!
    i hear some guys say its a 30in tire, some say 31in tire and Ive even heard 32in tire !!! is anyone positive on this???
    i do believe, to be exact, its a 31.6in tire. is that right??
    what is the next size right above 265/75/16?? I have no lift and will be using the stock 16in rims and want to get the biggest tire possible. Ill remove my mudflaps if i have to. right now i have 265/75/16 duellers-bald
  2. Sep 2, 2010 at 5:10 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    a 265/75 is like a big 31 but concidered a 32 in the metric world. Next up would be a 285/75 which is a large 32 which is concidered a 33 in the metric world :)
    With 285s you would need a lift at least 2.5", wheel spacers or new wheels with 4.5" of back spacing and new UCAs if you went above 2.5" with your lift to fix any alignment issues you may have :)
    Hope this helps
  3. Sep 2, 2010 at 5:15 PM
    04prerunner
    kyle
    tampa, Fl
    2004 prerunner
    stock
    helped alot!! thanks. I will be getting the 265/75's for sure. I cant do a lift right now :eek: but maybe down the road.
    is the 265/75/16, 10.5in wide or 11.5in wide? i think the 11.5's would look better
  4. Sep 2, 2010 at 5:16 PM
    04prerunner
    kyle
    tampa, Fl
    2004 prerunner
    stock
    with the 11.5's i may have a rubbing issue though, what do you guys think?
  5. Sep 2, 2010 at 6:31 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    You will rub with the 11.5s if you have stock wheels because they aren't back spaced enough...you"ll have to get 1.25" wheel spacers to avoid it or more back spaced wheels, 4.5" is ideal for most applications...but thats with the 285s so you don't have to worry. Its the 265s that are a little over 10" wide :)
  6. Sep 2, 2010 at 10:31 PM
    kyle39
    kyle39 Reppin' BC
    Kyle
    Vancouver BC
    04 Tacoma Trd
    Deck plate mod, rhino lined, A.r.e. flush glass shell, 265/75/16 Duratrac's, MB72 rims, Full OME lift, Dakars in the rear, Tint allround
    these are 267/75/16 no lift, no rubbing at all!
    You just have to make sure the backspacing on the rim fits with the tire, mines -6
  7. Sep 2, 2010 at 10:40 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    265/75/16s will fit with stock wheels...I ran that size with my old 1st gen for quite a while with no issues
  8. Sep 2, 2010 at 11:43 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Correct me if I'm wrong but stock 16x7 wheels have 4.5" bs already. I had 16x8 alloys that had 4.5" bs and ran 265 75 r16 with small lift no rubbing. Just got 4" bs wheels so I can step up too 285's and not have as much rub as with 4.5" bs.
    265 75 r16 u will be fine :)
  9. Sep 3, 2010 at 12:19 AM
    Tommo
    Tommo Well-Known Member
    Fairfax, VA
    base 4X4
    What about 275/70/16s, will they rub?
  10. Sep 3, 2010 at 7:31 AM
    iDigTulsa
    iDigTulsa Well-Known Member
    Luke
    Tulsa, OK
    03 DoubleCab TRD SR5 4x4
    Free Alarm Mod, Grey Wire Mod, Reverse Leaf Spring Helper Mod, Kenwood Deck, Memphis 10'', Yakima Roof Rack, Debadged Sides,Silver Toyota Skid Plate, Injen CIA, 3.5'' Amsoil Dry Filter, 17 x 7.5 Tundra Split Spoke Alloy's
    Much like the rest of us I, I have done extensive research on what new tires I will be purchasing in the near future. I found this site a while back and it has an incredible Size Calculator. You input the "stock" size, then you have the option to add up to four (4) separate tire sizes. It then shows you a side by side comparison on the differences in overall diameter of your choices.
    http://www.1010tires.com/TireSizeCalculator.asp
    Check it out, it's been a very informative tool for me so far, and I thought I would share it with my TW brothers and sisters.
  11. Sep 7, 2010 at 11:40 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
  12. Oct 26, 2010 at 9:24 PM
    01taquito
    01taquito "thats what she said"
    joe
    san antonio
    01 pre-runner sr5 quad-cab
    Bilsteins 5100's front and back. Wheelers add a leaf
    i know alot guys ask what is the largest size is for stock wheels but i have a 2 1/2" lift and my wheels are 16x8 (which is an inch wider than stock) and 4" back spacing. i really would like to know if i can go with a 285/75r16 without issue. my current tires are 265/70r16 but it seems like the sidewall has shrunk due to my new wheels being wider. any info would be greatly appreciated... any smart ass comments will not be appreciated. i already tryed the search button which is how i found this old post thx
    this is how it sits currently
  13. Oct 26, 2010 at 10:06 PM
    pittim
    pittim mittip backwards
    Pink slider.
    yup, factory TRD wheels are 4.5" backspacing.
    OP, 265/75/16 is roughly a 32x10.5x16.
    taquito, the "70" in 265/70/16 is the height of the sidewall compared to the width of the tire (the 265, in mm)
    a 265/70/16 tire is 265mm wide, or roughly 10.5 in. 70% of 10.5 is ~7.4. This means the sidewall is 7.4 in tall. Double that, add the wheel diameter, and you get the height of the tire (~31")
    Your 285/75/16s were about 11in wide, so the sidewall height was around 8.3in
  14. Oct 27, 2010 at 1:58 PM
    04taco2wd
    04taco2wd Take your flame, ignite the world!!!!
    Colby
    Southern Pitt,NC
    06 AC 4x4 SR5
    6" Fabtech Lift, Custom bedside decals, ICON C/Os, 17x9 Cruiser Alloys, 33x12.5x17 Coopers, UWS Lopro Toolbox, more to come...
    So your sayin 285/75/16 should fit on 2.5 lift with 16x8 4" backspacing wheels?
  15. Oct 27, 2010 at 2:00 PM
    pittim
    Pink slider.
    You can get 35s to fit on no lift.
    A lot of people run 33x11 on a 2-3in lift. You might have to massage some stuff in the fenders, but not much.
  16. Oct 27, 2010 at 3:37 PM
    01taquito
    joe
    san antonio
    finally a solid answer. thanks brutha:D
