New TIRES!!!! Help me pick!
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, Apr 1, 2010.
  1. Apr 1, 2010 at 7:12 PM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    hey guys so im in the market for some 265/75-15 tires. but i really want the km2's and i can only find them in 31/10.5/-15 will that size still work without rubbing?
  2. Apr 1, 2010 at 7:21 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    does it have a lift?
  3. Apr 1, 2010 at 7:24 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    ohh sorry my bad nope no lift :( i keep feeling like 31's are going to be too big i might just have to go with 235's
  4. Apr 1, 2010 at 7:28 PM
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    no deal it'll work, i had 31-10.50-15 goodyear MT/R's on my 04 taco with no scrubbing they did fine
  5. Apr 1, 2010 at 7:29 PM
    Hops
    Hops Well-Known Member
    Gabe
    south mississippi
    08 Silver Streak Mica Access Cab 4X4
    Shock and leaf spring TSB, Neoprene seat covers, weathertech digital fit floor mats, vent visors, bug shield, secondary filter removed, K&N drop-in filter, century camper shell, 265/75R16 ATM's...
    I had some 31 inch mudkings on my 99 model. A very small amount of rubbing on the front fender was the only problem i had.
  6. Apr 1, 2010 at 7:44 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    yeah but my truck is sagging pretty good and i see these tires weigh ALOT and im getting 24 mpg average right now and am going to miss it.
  7. Apr 1, 2010 at 7:45 PM
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    ok get a smaller set
  8. Apr 2, 2010 at 5:49 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    ok i see they have 235's im going to try to see if i can find a set of 245's somewhere
  9. Apr 2, 2010 at 6:24 AM
    saweetlou
    saweetlou Well-Known Member
    Guelph Ontario
    TRD Dbl cab long bed
    3in spacer
    What size rims do you have 15 or 16, I have 265/75/16 and they rub, thats 1 size over stock.
  10. Apr 2, 2010 at 6:40 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    no i have 15's
  11. Apr 2, 2010 at 7:26 AM
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    MGM 21 TRD OR 6sp MT
    Soon...
    My 99 taco had 265/75r15s stock and 31s are just about the same size. Had 31" km2s on my truck when I needed new tires, but my truck got higher and the tires got bigger.
  12. Apr 2, 2010 at 8:11 AM
    SigSense
    SigSense Well-Known Member
    13 TRD Sport DCLB 4X4
  13. Apr 2, 2010 at 8:36 AM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    My truck has 31 before I lifted it and still have them on their til i get new ones but they will work and I have 15's to
  14. Apr 2, 2010 at 9:58 AM
    Brutus
    Brutus Well-Known Member
    Butus
    Baltimore, MD
    2012 Crew Cab Sr5 TRD 4x4
    what width are the 31s everyone running? I too am looking for new tires for my 03 4x4 QC w/ no lift.
  15. Apr 2, 2010 at 10:01 AM
    tacomakid96
    Phil
    Out n' about
  16. Apr 2, 2010 at 11:55 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    go with 31x10.50x15's
  17. Apr 2, 2010 at 11:59 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
  18. Apr 2, 2010 at 12:59 PM
    99yodataco
    Chad
    Soon...
    X2
  19. Apr 2, 2010 at 1:05 PM
    Brutus
    Butus
    Baltimore, MD
    what if someone were to have 16" rims?
  20. Apr 2, 2010 at 2:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    In spite of the 31 in the name, a 31/10.5/15 tire is typically about 30.5 inches tall. If you are using the stock offset (15 mm) Tacoma wheels, this size will fit very nicely (with no rubbing) on an unlifted Tacoma.
    The same size tire measured metrically for the 16" stock wheels is 265/70/16.
