New tires needed
Discussion in 'Wheels & Tires' started by fullback, Oct 28, 2012.
  1. Oct 28, 2012 at 11:03 PM
    fullback
    fullback [OP] Well-Known Member
    NJ
    Double Cab TRD short bed
    2009 TRD 4x4 with almost 100 k HWY miles on these Original 265- 65-17 tires the outside of my tires are beginning to wear a lot faster, couple of thousand miles ago the dealer did a wheel alignment ,i didnt think i needed it but got it done anyway , would low profile tires fit on these original rims ? or should i stay with the original size ? A any thoughts or ideas are appreciated
  2. Oct 28, 2012 at 11:19 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
  3. Oct 29, 2012 at 12:42 AM
    krob32
    krob32 Well-Known Member
    Kelly
    Ft. Knox, KY / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    You can go up to 265/70/17 without a lift and still have no rubbing or trimming with little effect on mpg. You can go lower profile, but you need to determine if you like the look. Most go higher for look and more rubber means less opportunity of damage to the rim if you run over something on or off road.
  4. Oct 30, 2012 at 12:05 AM
    fullback
    NJ
    Thanx for the info
