New tires, no lift.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eatdrinkadam, Oct 9, 2015.
  1. Oct 9, 2015 at 3:47 PM
    eatdrinkadam
    eatdrinkadam [OP] New Member
    Adam
    2014 Tacoma SR5 double cab
    Hey everyone.
    First time poster here. My question is very simple:
    I am buying 16x8 wheels with 265/75/r16 Cooper Discover AT tires.
    Will they fit my stock (no lift) 2014 tacoma double cab 4x2, without obstructions of the wheel well?
    PS my mud flaps are removed.
    Thanks in advance.
  2. Oct 9, 2015 at 4:09 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to the forum. Yes, that is the max tire size that will fit without any lift. You shouldn't have any issues. There are mini front flaps that hang down in front of the front tire, below the front bumper. Depending on the offset you might rub on those in reverse. Simply remove them, they are held on with 2 small bolts. I have a picture of the flap in the KO2 link in my signature.
    Edit: When you are buying your tires, look for P-load if you are a street only truck, or C-load if you see some trails that may damage your sidewalls. Avoid the heavy E-load tires.
