New Tires Rubbing, Advice on Lift/Leveling kit for 2012 TACO
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prux56, Jan 18, 2017.
  1. Jan 18, 2017 at 7:31 AM
    prux56
    prux56 [OP] Well-Known Member
    2012 White Tacoma TRD
    Hello,
    I recently purchased some aftermarket 17" rims for my 2012 that look like TRD beadlocks and some BFG KO 2's 265-70-17 and I have some pretty good rubbing at about 60% turn in either direction. I went and ordered some of those RokBlokz mud flaps hoping to alleviate the issue but its almost the same rubbing on the cab side of the front tires.
    As it now looks like I will have to put in some kind of lift or leveling kit I was hoping I could find some expertise on this site. I am not looking to do any off-roading with the vehicle and don't want to increase the tire size anymore so I am hoping some folks could weigh-in on how to fix the rubbing while not adversely affecting the handling or suspension components. I am looking for what the most cost-effective way to fix the rubbing but if I have to spend a little more to maintain or even improve handling while not messing with the suspension geometry I will happily pay for what is needed.
    Thanks in advance for your help,
    P.
  2. Jan 18, 2017 at 7:43 AM
    Pigpen
    Dan
    Northwest Montana
    Can you see where it's rubbing? I ran 265/ 75/ 16 on stock suspension for a couple years with zero rubbing with stock mud flaps. I'm surprised you're getting that much rubbing. Now I run 33s (255/85/16) on a 3" lift with almost no rubbing. The little rubbing I get doesn't bother me.
    Any excuse for a lift is a good one, though!
  3. Jan 18, 2017 at 7:48 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    Check the little front flapper things as well. They are more prone to rubbing than the big flaps. That said, your decision on flaps was a good move as well.
  4. Jan 18, 2017 at 7:49 AM
    HoulaHauler
    HoulaHauler Well-Known Member
    Andy
    Gwinnett Co., Georgia
    2013 1G3 DCSB
    Rough Country makes a billet 2" leveling kit for $60
  5. Jan 18, 2017 at 7:52 AM
    Caltech90
    Caltech90 Well-Known Member
    '19 TRD OR T4R
    I wouldn't go with a spacer lift.
  6. Jan 18, 2017 at 7:52 AM
    Larry21
    Larry21 Toyota enthusiast- Tacomas to Supras love them all
    Larry
    San diego
    2012 dcsb tacoma prerunner
    trd exhaust, homertaco grill insert, waiting for camburg spindles and uca fox shocks
    It looks like someone is selling a hell bent 2.5" leveling kit for $40.00 on here.
  7. Jan 18, 2017 at 7:54 AM
    Larry21
    Larry
    San diego
    I agree with caltech tho. I wouldnt do the leveling kit unless its temperary to get you by without rub while you choose a lift that you will stay on the truck.
  8. Jan 18, 2017 at 7:55 AM
    prux56
    Pigpen,
    thanks for the quick reply. Yes the rubbing is just behind the tire on the bottom edge of the wheel tub/firewall when 60% or more turning.
    And from the other posts I take it you guys are suggesting a leveling kit?
  9. Jan 18, 2017 at 7:57 AM
    prux56
    Thanks Larry, I would just as soon make one modification to the vehicle as opposed to two. So what kind of lift do you suggest and what height? I would like to stay under 2" if possible.
    P.
  10. Jan 18, 2017 at 8:14 AM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    I certainly would not shy away from a leveling kit, see my link below. The caveat here is how many miles on your front shocks? If your running the oem and have regular miles for the age then it would be smart to get the Bilstien 5100's instead of a spacer.
    .02 cents.
    Abragus likes this.
  11. Jan 18, 2017 at 8:24 AM
    prux56
    Larry,
    thanks for the quick reply. I have about 110,000kms on my truck so it might make sense to go the shock route. Would I have to change anything in the rear? Does it make sense just to do them all at once? I do not mind spending the money if that makes sense.
  12. Jan 18, 2017 at 8:31 AM
    Caltech90
    '19 TRD OR T4R
    All that lift and you rub with 31s??
  13. Jan 18, 2017 at 8:37 AM
    Caltech90
    '19 TRD OR T4R
    Dang they must be super wide.
  14. Jan 18, 2017 at 8:49 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    When it came time to replace my 2012 stock shocks, I went this route...... It's a vast improvement! I plan on keeping my truck forever, so I see no reason not to put quality parts on it.
  15. Jan 18, 2017 at 9:43 AM
    Larry21
    Larry
    San diego
    I agree with this!
  16. Jan 18, 2017 at 9:45 AM
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    "Trying again" is what I wanted to avoid. Buy once, cry once, they say.
  17. Jan 24, 2017 at 10:51 AM
    prux56
    Hey,
    thanks for the input from everyone, I will begin planning on sourcing new adjustable shocks but I wanted to ask what else is recommended. Should I replace the coils at the same time (Toytec?) given that I don't plan on any off-roading but would be interested in improving the road ride of the vehicle.
    And should I also buy the differential drop kit for the front as well?
    I have also seen a small spacer provided in some kits to level out the drivers side versus the passenger side, seems like the right way to go but was hoping someone could weigh-in.
    And lastly, does anyone know of a good vendor in Canada? The cheapest place I have seen for a comprehensive kit is here (http://bigcountrycustoms.com/product/bilstein-adjustable-lift-kit-with-5100-shocks/) but I would like to do better if I can.
    Thanks for everything,
    P.
  18. Nov 6, 2017 at 9:13 AM
    prux56
    Hey,
    I just wanted to give an update. I now have the Big Country lift kit and shocks installed all the way around. The look and feel of the truck is great although I am worried about some vibration in the front differential. I installed all the spacers to drop the front differential so we will see how it wears over time. As well I am still experiencing some rubbing on the front stock mud flaps at hard turning. I have managed to heat up and remold the front flaps which has greatly reduced the rubbing but it is still present on the right side.
  19. Nov 6, 2017 at 9:31 AM
    prux56
    Forgot to post a pic. Here is the finished vehicle
    blksandpearl2010 likes this.
