New Tires Rubbing-need fix
Discussion in 'Suspension' started by Petemobiledj, Mar 2, 2010.
  1. Mar 2, 2010 at 12:15 AM
    Petemobiledj
    Petemobiledj [OP] Member
    Pete
    Texas
    08 Tacoma 4x4 Sport
    2.5" Front Level Kit, 285/70/17 BF Goodrich Mud-Terrain T/A KM2
    I have a 2008 Taco Sport. I purchased BF Goodrich MK2 285/70/17. I was told that all I needed was a leveling kit for the tires to fit. I installed a 2.5" front level kit(spacer) and ended up with the first problem-front is taller than the rear! Once the new tires were mounted and placed on the truck we found out they rub the wheel well. Does anyone have a solution for this?
  2. Mar 2, 2010 at 12:28 AM
    only_K
    only_K 1st Gen. Pride
    Kevin
    Turlock, CA
    99 Tacoma PreRunner
    K&N drop in filter, Magnaflow Exhaust, Billet grille. All 4 Bilstien 5100s. Fronts set at 2.5". Rear 2" AAL.
    lift it higher.
  3. Mar 2, 2010 at 6:07 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    You probably have to remove the front mud flaps, trim the fender liner in the front of the wheel well, and trim the fender at the rear where it curves in. Basically just turn the wheels and get out and look where it may be rubbing
  4. Mar 2, 2010 at 6:34 AM
    wallytaco
    wallytaco Active Member
    Pittsfield, MA
    '10 MGM Access V6 OR
    I'm sure you're about to get hit with the "use the search" whip, but since this is your first post and only my 9th, I'll leave that to someone else. I've been researching this site non-stop since picking up my '10 Tacoma a month ago.
    I'm going to assume you have stock wheels and you're probably rubbing the upper control arm. The cheepest solution up front would be to order 1.25" spacers, you'll need hubcentric. Get them all around though, or it'll look like a Civic dragster. Spidertrax are the most popular recommendation and many seem to run those. With 285s, you'll have to remove your front mud flaps and there will still be a need to do very minor inner fender trimming.
    If you haven't had the TSB done, where the dealer changes out the rear 3-leaf pack for a 4-leaf, the stock rake on the truck is about 1.75". The TSB adds about .5" to 1" of height. So if you went 2.75" up front, it will be higher on that end. With the TSB, you'll be close to level. However, to truly level it back out, you'll need an add-a-leaf (preferred method) or a block.
    I've gained all this knowledge from the search feature in researching my setup. Not being a prick, but if you look around here long enough, you almost never need to post for info requests.
  5. Mar 2, 2010 at 6:52 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  6. Mar 3, 2010 at 12:12 AM
    Petemobiledj
    Pete
    Texas
    08 Tacoma 4x4 Sport
    Thanks for all the great replies. I have went ahead and trimmed the wheel fenders on the inside and removed the mudflaps. It stopped rubbing there but I notice there is a piece of the frame in the direction of the rear that will potentially rub when off roading. I think I will have to just order a 3" lift for the front to keep it from hitting. I did have to get new rims with a -12 offset that pulled it away from the control arm so no issues there. I have a 1.5" block ordered and on its way for the rear. I didnt do the add a leaf because I figured it would make the ride a little to rough.
  7. Mar 3, 2010 at 12:15 AM
    Petemobiledj
    Pete
    Texas
    08 Tacoma 4x4 Sport
    What is the TSB? is that leaf replacement some kind of recall?
  8. Mar 3, 2010 at 6:16 AM
    wallytaco
    Pittsfield, MA
    Dude, it's official, you need to try the search function!
  9. Mar 3, 2010 at 8:22 AM
    Petemobiledj
    Pete
    Texas
    08 Tacoma 4x4 Sport
    lol...sorry I had a hard time even trying to figure out how to put up mu first post.
  10. Mar 3, 2010 at 8:34 AM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Where is the pinch weld located? Sorry for the newb question.
  11. Mar 3, 2010 at 8:38 AM
    sethr21785
    sethr21785 Well-Known Member
    Seth
    Windham Maine
    09 TRD SPORT
    TRD Short Throw, TRD Exhaust, 5100 1.5, Weathertech floor liners, AFE Filter, Projector Head and fogs, Weathertech vent visors
    TSB stands for technical service bulletin. Its not a recall. If you bring your truck to toyota and tell them you have a harsh ride while under load they will replace your rear leaf springs with a four pack. It raises the rear of your truck about an inch.
  12. Mar 3, 2010 at 9:29 AM
    Petemobiledj
    Pete
    Texas
    08 Tacoma 4x4 Sport
    Ok, I just called the dealership and unfortunately I have 38,000 miles and it was only covered to 36,000. If I want to pay for them they are $630 per leafspring. Hell for that I might as well order some Deaver leafs.
  13. Mar 3, 2010 at 11:10 AM
    wallytaco
    Pittsfield, MA
    Not a big deal. Sorry to hear that you're out of warranty. You don't necessarily need the TSB, but it would have helped you achieve something closer to level without shelling out money. I'd recommend looking into an add-a-leaf from toytec or wheelers. 2" should get you where you want to be.
  14. Mar 3, 2010 at 12:02 PM
    Petemobiledj
    Pete
    Texas
    08 Tacoma 4x4 Sport
    I just ordered a 1.5" block and hopefully it will do the trick. I am guessing doing both would look a little weird.
