New Tires/ Stock Rims
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RyHodg77, Feb 7, 2021.
  1. Feb 7, 2021 at 10:02 AM
    RyHodg77
    RyHodg77 [OP] New Member
    2021 Gray Tacoma SR
    So I just got a 2021 Tacoma, and right away I want to put some new tires on this thing. Long term I’m going to do a ton to this truck but for now living in Colorado I need something better than the stock tires that came on the truck. Curious if anyone has any experience putting on bigger tires with the stock SR rims. My main concern is that the bigger tires may rub the control arm due to the little bit of positive(?) offset the stock SR rims have. Anybody have any experience or suggestions for tire sizes?
  2. Feb 7, 2021 at 10:06 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    On my stock 16 in steel 16x7 wheels, I put toyo at3 265/70r16 tires on no problem. I have two finger space from the spindle and no body rubbing. I then found fj wheels same size and transferred the tires over.
  3. Feb 7, 2021 at 10:08 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    You may get better answers by offering some data....
    What size wheels are on the truck now?
    What size tire is currently on the truck?
    Your tire selection will be limited by the wheel size and dimensions.
  4. Feb 7, 2021 at 10:12 AM
    TKitchTaco
    TKitchTaco Subs for work tacos for play
    Trent
    Jersey shore
    2020 AC SR SX super white
    Desert Does it Seat jackers LasFit LED headlight/taillight kit Plastidipped wheel emblems tailgate inserts
  5. Feb 7, 2021 at 10:14 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    235/85/16 and no rub.
    Junkhead likes this.
  6. Feb 7, 2021 at 7:45 PM
    andrewbrandon19
    andrewbrandon19 Well-Known Member
  7. Feb 7, 2021 at 7:52 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    265/70/16 is an optional stock size. They are the same height as the more common tires and about 3/4" wider. You can go to 265/75/16, or 265/70/17 depending on whether you have 16" or 17" wheels. Both of those have nearly identical overall dimensions about 1" taller, and 3/4" wider than stock. That is as big as you can go without modifying the truck and you'll have no issues with the factory wheels.
    Unless your truck came with cheap steel wheels there are better things to spend your money on than new wheels. The factory ones are fine.
  8. Feb 7, 2021 at 8:00 PM
    Tigris99
    Tigris99 Well-Known Member
    St Louis
    2021 AG Trail edition
    FYI being in Colorado you should know that bigger tires aren't the ultimate answer. Can do a lot better than stock extremely easily though.
    Everyone has covered what sizes you can do without issues.
  9. Feb 7, 2021 at 8:05 PM
    Yes_that_Kiwi
    Yes_that_Kiwi Well-Known Member
    2021 TRD Off Road
    I am pretty sure 265/75/16 would fit no problem, if you are looking for an over all all terrain tire I would look at the Wrangler DuraTrac.
    bulalo likes this.
  10. Feb 7, 2021 at 9:02 PM
    TKitchTaco
    Trent
    Jersey shore
    Best thing to do is to look at the off-road vehicles that live in your area and go with what they’re running. If you can talk to the owners of said vehicle even better. Just a tip I picked up from the mountain biking world and seems to do well with car tires too
