new tires tomorrow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marioso, Dec 12, 2008.
  1. Dec 12, 2008 at 5:41 PM
    Marioso
    Marioso [OP] Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    will have pics tomorrow or sunday...guess what i got a flat today, one day! before i get new tires unbelievable...
    i have a 2.5 in lift in the front are 265 the biggest i can get without trimming or rubbing?
  2. Dec 12, 2008 at 5:53 PM
    Frisbie
    Frisbie Member
    Westerly RI
    02 Tacoma Limited
    I had 265/75R16's on a stock 02 tacoma with no rubbing. On a side note, 31x10.5x15 on the same truck rubbed a little and I had to take my front mud flaps off.
  3. Dec 12, 2008 at 5:55 PM
    Marioso
    San diego Ca
    265 r stock im wondering if i can go bigger without rubbing or trimming
  4. Dec 12, 2008 at 6:07 PM
    Frisbie
    Frisbie Member
    Westerly RI
    02 Tacoma Limited
    So 265/70R16's are stock. I had 265/75R16's installed not to long after I got the truck. I believe if you any larger than that with a stock tacoma, you will need to do a little trimming.
  5. Dec 12, 2008 at 6:15 PM
    Marioso
    San diego Ca
    is a 2.5 lift stock?
  6. Dec 12, 2008 at 6:39 PM
    Frisbie
    Frisbie Member
    Westerly RI
    02 Tacoma Limited
    Nope...with a 2.5" lift, you could probably get away with 285/75R16's (~ 33" tire).
  7. Dec 12, 2008 at 6:45 PM
    Frisbie
    Frisbie Member
    Westerly RI
    02 Tacoma Limited
    Do a search in the "wheels & tires" section...tons of great advice! The tire section tool works great too!!
  8. Dec 12, 2008 at 6:50 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Hey mario go with 265-75 if you go bigger you will trim even with a 2.5 lift
  9. Dec 12, 2008 at 6:53 PM
    Marioso
    San diego Ca
    nice thanks guys
  10. Dec 12, 2008 at 6:54 PM
    allupinsydeyou
    allupinsydeyou Well-Known Member
    so cal / vegas
    v8 swapped yota. dyno tuned @ 400hp
    modified total chaos uppers and lowers... king coilovers, deaver leafs, full cage, 351w motor swap, etc..
    bigger = re-gearing time... you sure you have the dough to drop on something like that?
  11. Dec 12, 2008 at 6:57 PM
    Marioso
    San diego Ca
    got the dough but id wanna spend it on something else 265 it is
  12. Dec 12, 2008 at 6:59 PM
    allupinsydeyou
    so cal / vegas
    smart. just remember.. upsizing a tire and not re-gearing means more strain on your drivetrain. that isnt good... leads to blown trannys and all sorts of other fun stuff.
  13. Dec 12, 2008 at 7:02 PM
    Marioso
    San diego Ca
    sick cool...how about downsizing rims...stock it comes with 17 in and the guy who had it before me put 16's
  14. Dec 12, 2008 at 7:04 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    16's = cheaper
  15. Dec 12, 2008 at 7:07 PM
    allupinsydeyou
    so cal / vegas
    no... rim size doesnt matter...no idea why he would step down to a 16 unless he was going to actually use it in the dirt more, but ok lol.
    as for upsizing tires... the simplest way i can word it is like this...
    your rear end is geared for the best mix of both worlds from the factory with a specific size tire in mind. they gear it for the amount of torque and top end you will need to drive it while also trying to achieve the best gas milage. when you step up to a bigger tire, you are throwing in (for lack of better words) more rotating mass. basically it takes that tire longer to complete one full revolution than the stock size did. so you would have to regear in order to get it back to that correct turn ratio of 1 tire turn per x amount of pinion gear turns. hope that is easy enough to understand.
  16. Dec 12, 2008 at 7:08 PM
    allupinsydeyou
    so cal / vegas
    and incorrect there buddy steve-o. 16's to alot of tire manufactures are considered a odd ball rim size. in some cases it is actually more expensive to get a tire with a 16 inch wheel hole then it is for the same size tire with a 17 inch wheel hole.
  17. Dec 12, 2008 at 7:10 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    17's are more expensive tire and that i have a 16" rim tires are cheaper for me
  18. Dec 12, 2008 at 7:12 PM
    allupinsydeyou
    so cal / vegas
    which tire company you go for? i know for the bfg baja's it was almost 25 bucks more for a 16 then it was for a 17 when we were lookin for them for jp's class 1 car i was tellin you about.
  19. Dec 12, 2008 at 7:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You wont need to re gear with a 265/75/16 wheel and tire, and they should fit just fine. In a 17" wheel, look for a 265/70/17.
  20. Dec 12, 2008 at 7:20 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    I stand corrected my friend 17's are actually cheaper for bridgestone dueler revos :smack: but i guess it the brand too
