New tires truck still shakes above 53mph
Discussion in '1st Gen. Tacomas (1995-2004)' started by bourdlay, Oct 31, 2011.
  1. Oct 31, 2011 at 11:28 AM
    bourdlay
    bourdlay [OP] Member
    Dave
    Michigan
    4x4 2.7 manual reg cab
    Hello,
    My 4x4 2.7 reg Cab tacoma shakes bad above 53mph. It shook a little before the new tires at those speeds, but now with the new tires it shakes real bad. If I have had the tires balanced could the alignment be so bad to make the truck shake this bad? I am having the alignment done this week, but I don"t know if it will make it ride better. Any input is greatly appreciated.
    The rims are clean as in no dirt on the inside the tires were perfessionaly mounted and balanced by Walmart. Not a good source, but the deal on the tires will hopefully make up for it.
  2. Oct 31, 2011 at 11:35 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    make sure they are balanced correctly.
    EDIT - "professionaly balanced and mounted at wal-mart" is quite contradicting.
  3. Oct 31, 2011 at 11:47 AM
    bourdlay
    Dave
    Michigan
    This adapter I found when googleing the issue, is it really required for Toyota rims, can a shop properly balance my tires without this AKA Toyota Rim adapter?
  4. Nov 1, 2011 at 3:16 AM
    drwb
    drwb Well-Known Member
    Allen
    Glendale, CA
    04' TRD 4X4
    OME 880 coils Wet Okole seat covers
    I have heavier tires and heavier wheels and at first mine was shaking between 65-70. I got it rebalanced from the same people and it still shook. My next thought was I might of got a bent steel wheel from procomp?? So I went back to 4wheelparts where I bought the wheels from and they checked them out and nothing was wrong with the wheels. They rebalanced my tires and NO more shaking! So it really makes a world of a difference on who balances your tires.
  5. Nov 1, 2011 at 6:11 AM
    bourdlay
    Dave
    Michigan
    Ya I am going to have a local shop that has a good reputation rebalance the tires and give it an alignment for the life of the tires sake. I will check back with the results after that. Thanks everyone for the suggestions.
  6. Nov 1, 2011 at 10:18 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Are you getting a single or dual plane dynamic balance?
    The shake could be alot of things..from grooved balljoints to driveline(u-joints) to you might just need a alignment like you assume..
  7. Dec 14, 2013 at 9:17 PM
    Ralston
    Ralston Well-Known Member
    Al
    High Rockies, CO
    Super White - 4x4 - TRD Off Road
    So what did they say?
  8. Dec 14, 2013 at 9:50 PM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    If the shaking got worse after the new tires, they definitely need to be properly rebalanced.
    As far as I've experienced, wheel shake is usually caused by 1) bad/worn tie rods, 2) front wheel bearings, 3)unbalanced wheels I suppose. Check the play in the tie rods and wheel bearings. It's pretty easy. Just jack up the front end and try to shake your wheels horizontally and vertically. Horizontally = tie rods, vertically = wheel bearings. If both of those check out to be reasonably tight and without play, then move onto balancing the wheels again.
  9. Dec 15, 2013 at 8:43 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    Driveshaft might be out of balance. Any damage to it?
  10. Dec 15, 2013 at 8:53 AM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    get a road force balance.
  11. Dec 16, 2013 at 10:50 PM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    I always like to purchase 'lifetime balance' and get tires balanced every time i do oil change.
  12. Dec 16, 2013 at 10:52 PM
    Zer0
    SGV, California
    99 PreRunner
    What wheels and tires are those on your truck? What size too? Are those 6 lug. I have a 99 prerunner and want to upgrade the wheels/tires to a similar look that you have. Sorry to copy you but those look like a good combo setup.
