New Tires turned brown
Discussion in 'Wheels & Tires' started by mattioss, Feb 19, 2011.
  1. Feb 19, 2011 at 1:19 PM
    mattioss
    mattioss [OP] Well-Known Member
    Milford, De
    08 Prerunner DB TRD Sport
    None
    Hey guy,
    I got new tires about 2 weeks ago and the front two tires have since turned brown and they won't come clean. I've tried everything to clean them and they are still this disgusting brown color. The rear drive tires are still black no signs of browning. I haven't driven through mud, dirt, sand hasnt been sitting in sun.
    They are BF Goodrich tires and its not just the sidewall but the tread too. Any ideas?
  2. Feb 19, 2011 at 1:22 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    What did you clean them with?
  3. Feb 19, 2011 at 1:23 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    I believe that is called "Blooming"..It's just something that naturally happens to it sometimes....idk if the tread is supposed to though, I could be wrong about it all..Hopefully someone else chimes in and knows!
  4. Feb 19, 2011 at 1:27 PM
    mattioss
    Milford, De
    None
    I took it back to the dealership who installed the tires and whatever they tried using some industrial cleaner, I tried regular Meguiras tire cleaner, simple green and just thats it. The dealership told me to call BF Goodrich and talk to them about it
  5. Feb 19, 2011 at 1:27 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    ^^^ yup!
    unfortunately your stuck with it, all you can do is hide it with tire dressing.
    it's to keep the outside of the tire from rotting and cracking, like stated.
  6. Feb 19, 2011 at 1:29 PM
    mattioss
    Milford, De
    None
    but my question is why did only two of them do it and not all 4? and why is the tread brown? wouldnt that have an affect on the drive of the truck possibly on slick roads?
  7. Feb 19, 2011 at 1:31 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    Take some pictures of the brown tires, so we can see how "brown" they really are and maybe someone can relate or something
  8. Feb 19, 2011 at 2:23 PM
    JDMcQ
    TRy some Wesleys Bleche White. It might help.
  9. Feb 19, 2011 at 2:46 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    This is really strange if they are as brown as you make it seem. I've gone through around 6 sets of bfg a/t's over the years and never had that happen. I slight discoloration maybe but that's normal. Without pictures to see I'd say your referring to a black tire with maybe a slight browish tint when looking at it in sunlight. Do you use some kind of tire dressing stuff? I"ve never used any of that crap but it could be what is causeing the brown appearance when the sun hit's it.
    Edit...so the tread is also brown? It allmost sounds like a bad batch of rubber or something. How old are the affected tires? You can google to find out how to read the sidewall to find out the month and year of manufacture. This is really strange....
  10. Feb 19, 2011 at 3:06 PM
    mrmumbels
    mrmumbels Well-Known Member
    Land O Lakes, fl
    09 prerunner
    none
    I was just going to say that! I'd almost put money on it that it'll work. There's a few other tire cleaners that do the same thing though. Careful getting it on aluminum.
  11. Feb 19, 2011 at 3:12 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
  12. Feb 19, 2011 at 3:14 PM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    this is what bleche white will do
  13. Feb 19, 2011 at 3:33 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    because it happens randomly to some tires.
    I'd talk with bfg for sure, because regardless of whether it's a safety concern or not, you bought black tires, not brown. hopefully they will fix it!
  14. Feb 19, 2011 at 4:32 PM
    OffroadToy
  15. Mar 2, 2011 at 5:41 PM
    mattioss
    Milford, De
    None
    Sorry it took so long to update but I contacted BFG and they explained the Oxidation to me and they said normally it goes away within 2-3 weeks they told me to use a mild dish soap with hot water and scrub brush daily if i wanted to speed it up, well guess what I have black tires again, looks sharp now!
  16. Mar 2, 2011 at 5:46 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    x2, that stuff is the jam
  17. Sep 15, 2011 at 3:15 PM
    Mark O
    Mark O New Member
    mark
    chattanooga
    2011 prerunner double cab 4*2 V6
  18. Sep 15, 2011 at 3:18 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Welcome Mark to TW
    Have you tried takeing a tire brush to that?
  19. Sep 15, 2011 at 3:19 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    I used Wesley's not too long ago, awesome stuff. A good APC will also work.
  20. Sep 15, 2011 at 3:49 PM
    Mark O
    Mark O New Member
    mark
    chattanooga
    That may be a good idea Blackshirts..
