New tires & Wheels
Discussion in 'Wheels & Tires' started by mizodh, May 16, 2023.
  1. May 16, 2023 at 9:26 PM
    mizodh
    mizodh [OP] New Member
    Joe
    2017 Toyota Tacoma TRD Sport
    I recently bought some 33x12.50R20 Nitto Ridge Grapplers and Vision Rocker 20x12 -51 mm for my 6 in lifted Tacoma. after installing them I noticed that the steering wheel vibrates I got the truck alignment done and rebalanced the tires. Any suggestions on what might be wrong
  2. May 17, 2023 at 4:57 AM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    What tires and wheels were on it prior? Was it lifted 6" with those tires/wheels with no problems? Put them back on and see if it vibrates.
    Did you put the new tires/wheels on at the same time as the 6" lift?
  3. May 17, 2023 at 5:23 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Sounds like you got some miles on your truck. Over time, the front LCA bushings wear and get loose-they aren't new anymore. With the larger tires you're going to feel any worn components easier than the stock tires, so, I'm going to guess that your bushings need replacement. Inspection may not show much but might. I would also suggest that your LCA or UCA ball joints could also be contributing to your wobble, but a fresh set of Whiteline poly bushings in your LCA might be something you could look into. :thumbsup: Another thing you will want to look into is your front axle needle bearing; does the vibration go away when you put it in 4wd? IF yes, then look into replacing the needle bearing with the ECGS bushing.
  4. May 17, 2023 at 8:25 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    @mizodh make sure that whoever installed the wheels and tires used an E/T lug kit. It helps to center the wheel on the hub.
    thomasburk likes this.
  5. May 17, 2023 at 8:02 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    U joints ?
  6. May 18, 2023 at 9:49 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Two things to check,
    1. If the wheels are not hubcentric, make sure you're running the wheels with hubcentric rings.
    2. Use ET lugs if the wheels accept them.
    If the vibration is felt in the steering wheel, it's one of the front tire/wheel causing the issue.
    If those 2 items are taken care of and the vibration is still present, find a shop that offers road force balancing. IF that doesn't work then you probably have a bad tire even if it's new. If all 4 tires check out OK then one of the wheels is bad.
