New Tires
Discussion in 'New Members' started by scrappy76, May 2, 2013.
  1. May 2, 2013 at 7:03 PM
    scrappy76
    scrappy76 [OP] Member
    Arkansas
    2013 4x4 double cab long bed
    I just bought my 2nd Tacoma! Its a 2013 stock 4x4 longbed with 245/75r16.
    They seem way to small whats the largest size I can go without a lift?
    265/75r16? I dont want any rubbing
  2. May 2, 2013 at 7:05 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^That's it.
  3. May 2, 2013 at 7:09 PM
    scrappy76
    Arkansas
    BFG website said that the all terrain TKO were not recommended for my truck. Why would that be? weight difference?
  4. May 2, 2013 at 7:15 PM
    KenLyns
    Belly of the Beast
    Link? Where does it say it isn't recommended?
    The TX Baja edition comes with AT KO as OEM tires.
  5. May 2, 2013 at 7:18 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    i would think a C-rated tire would be ok, may ride a tad rougher but yes, the side walls are stiff on the at ko. But hell they put them on the tx baja, pro so why not. Just play w/tire pressure till you get a good ride and wear. ^^^^^^^^ sorry i type slow^^^^^^^^^
  6. May 2, 2013 at 7:20 PM
    KenLyns
    Belly of the Beast
    ...or go with a more modern AT tire... like my Hankooks that weigh just 3 lb more than stock.
  7. May 2, 2013 at 7:26 PM
    scrappy76
    Arkansas
    on the BFG website tire calculator is where I got that info, didn't say not recommended just didn't list as a choice for that tire. I had the BFG on my 98 limited for runner which I loved. They clean well in the thick Arkansas gumbo and also grip well when Im in the ozarks
  8. May 2, 2013 at 8:28 PM
    mikebuyscars
    mikebuyscars Well-Known Member
    Fenton, MI
    21 Toyota Tacoma double cab TRD Off-Road Voodoo Blue
    2 inch lift
    Someone had 285's on mine when I bought it and it has a 2 inch coil spacer up front and the tires were still rubbing on turns. I had them taken off because I didn't want to smash the sheet metal when I go off road
  9. May 2, 2013 at 8:29 PM
    mikebuyscars
    Fenton, MI
    2 inch lift
    The 265's are just fine!
