new tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tammikm, May 9, 2009.
  1. May 9, 2009 at 6:52 AM
    tammikm
    tammikm [OP] Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    can someone tell me what the difference is in these 2 tire sizes
    LT265/75R16 E AND
    LT265/75R16 D ??
    THE E series is more expensive by about $10 a tire.
    and would these be good all season tires and good for highway use?
    thanks
  2. May 9, 2009 at 6:54 AM
    Fishpig
    Fishpig Well-Known Member
    Lexington, VA
    2020 TRD OFF ROAD DCLB
    The E tire has more plys than the D and a higher load capacity
  3. May 9, 2009 at 7:10 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Hit the nail on the head. Its load ratings.
  4. May 9, 2009 at 7:34 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I wouldn't buy either for highway use unless you're towing.
  5. May 9, 2009 at 1:47 PM
    tammikm
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    what do you guys recommend for tires then? I want a tire that is aggressive looking good in snow and drives nice on the highway for all season use.
    thanks
  6. May 9, 2009 at 1:51 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    The BFG ATs are the most aggressive AT I have seen. Or you can try looking at tight lugged MTs. The KM2s look awesome!
  7. May 9, 2009 at 1:59 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    They aren't the most aggressive but I use Firestone Destination A/T's. I have nothing bad to say about them though I haven't used them in the snow. They're good on the highway, stable and low road noise. I will be taking a trip up to NJ next Saturday, as a matter of fact. Took the same 580 mile (each way) trip last June and they were great.
    One way to keep your MPG low is to buy P rated tires like I did. Like I said above, if you aren't towing or doing major off roading, there's no reason to get anything else. P rated tires will also cost you less. Mine were $504 installed at Firestone for 265/75/16's.
