New to forum, am very happy I found it
Discussion in 'New Members' started by John1972, Nov 20, 2019.
  1. Nov 20, 2019 at 8:31 PM
    John1972
    John1972 [OP] New Member
    1992 Toyota PU, 2019 Tacoma SR 4x4
    I am new here and am glad I found this forum.
    My original 1992 Toyota PU Truck is still running well with the odometer broken around 178,000 miles and my estimate is probably more like 230,000 miles.
    I recently got a 2019 Tacoma SR 4x4 and have driven it close to 300 miles on the odometer so far.
    It is still in break-in period and I am still babying it along.
    If anyone knows what the initials "ECT" stand for, I would appreciate knowing myself.
    I know it increases engine power and/or changes shift points to run the engine out longer and give it more power for passing or going up steep hills - but do the letters themselves, E.C.T., actually mean something?
    This board has already helped me a lot! With the key in ACC but the engine not turned on yet, I was also getting that full size red screen with "Check Charging System" warning - found out that is common and normal and just means the battery is on via ACC but the engine is not running, so obviously the alternator is not charging. So that warning light only applies to if the engine is running, should it come on - and while in ACC, it is some standard Toyota way of showing that a warning system is working, similar to how all the other dash lights come on then go off once started.
    So thanks !! That helped me out of a panic seeing that a few times since bringing it home, to know it is normal.
    I didn't get it for off-road but did want 4x4 to replace an AWD Forester I was trading in.
    It will take a while to learn when and when not to use 4x4 Hi, at what point are the roads wet or slippery enough that 4x4 is safe to use without damaging the system going around turns.
    I do want to add a shell and am thinking ARE or SnugTop. ATC does not seem as good and the dealership that handles ARE and SnugTop had a Leer on display and showed a cut-away of the roof top, with the ARE and SnugTop using a thick honey-comb for the roof between the two layers of fiberglass laminate, exterior and interior, versus the Leer cut-away showing a very thing layer of cardboard without much reinforcement.
    So it is probably ARE or SnugTop - and then get running boards because I have some medical disability issues and climbing up that high into the driver's side would be easier with step ups.
    The old 1992 is only 9" ground clearance and like getting into a car, very easy. It would be nice if Toyota and/or other truck manufacturers, in addition to the higher off the ground modern versions common today, would offer at least one model that is lower to the ground, similar to how in 1992 it was a much smaller "sports truck" look than the larger 2019 one is today.
    I am still enjoying breaking it in and learning the controls. The radio I am lucky to have tuned a few stations. When I am driving it's hard paying attention to driving and a flat touch screen at the same time - for myself at least - since I am old(er).
    Thanks for hosting a very informative forum. If I ever discover something new about the latest generation Tacoma, I will post it here, but so far, I am still learning just how to drive it and what all the buttons do.
  2. Nov 20, 2019 at 8:36 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  3. Nov 20, 2019 at 8:43 PM
    Bigdaddy4760
    Maner
    Poolville Texas
  4. Nov 20, 2019 at 9:36 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
  5. Nov 21, 2019 at 1:58 AM
    jeprox
    jeprox Well-Known Member
  6. Nov 21, 2019 at 2:02 AM
    FishnTx
    South East Texas
    ‘17 OR
  7. Nov 21, 2019 at 4:37 AM
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
    Welcome to the jungle!
    And soon your wallet will NOT be happy you found a group of new internet friends who will assist in spending your money.
    You have been warned.
    FastEddy59 and buckhuntin-tacoma like this.
  8. Nov 21, 2019 at 4:38 AM
    senecataco
    senecataco Well-Known Member
    2019 Cement OR DCSB
    None... yet.
    Welcome! And I’m 99% sure that ECT stands for “Electronically Controlled Transmission.”
    FastEddy59 likes this.
  9. Nov 21, 2019 at 7:19 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
  10. Nov 21, 2019 at 7:27 AM
    ArmandHammer83
    ArmandHammer83 This truck is AMAZING
    Raymond
    Alabama
    2018 Tacoma AC V6 MT 4x4
    none yet
    Welcome to the most loved and hated site on the internet...jump on in...the top right hand corner is a search bar type in a general term or abbreviation " LSD, ADM, MT, AT" just to be helpful with learning some of the terms used around here and it should show up almost anything you want to know..good luck sir..also we love pictures of trucks...just sayin
  11. Nov 21, 2019 at 7:27 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Welcome & Hello :wave:
  12. Nov 21, 2019 at 12:20 PM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Welcome!
  13. Nov 21, 2019 at 12:22 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
  14. Nov 21, 2019 at 3:28 PM
    Merlin88
    Merlin88 $8.95 large hawaiian
    Southern Oregon
    2017 Silver SR5 V6 4x4 DCSB AT
    SSO Slimline Hybrid Bumper Smittybilt X2O 10k Wireless Winch N-Fab Rock Rails w/Removable Steps Fab Fours Premium Rear Bumper RCI Engine Steel Skid RCI Transfer Case Steel Skid RCI Transmission Steel Skid RCI Crossmember Steel Skid RCI Fuel Tank Steel Skid Pop & Lock Auto Tailgate Lock Decked Short Bed Storage System ARB OME BP-51 2” Lift Kit with ARB OME BP-51 w/adj res coil overs ARB OME BP-51 w/adj res rear shock ARB OME Differential Drop Kit SPC UCA’s w/adj Ball Joints OME Dakar Heavy Duty Leaf Packs BFG AT KO2 T/A 285/70/17 tires Ultra’s Maverick 235 17x8 wheels Full Size Matched Spare Thule TracOne Ladder Rack Toyota Matte Black Grille Smoked Amber Raptor Grille Lights Matte Black Emblems Toyota Chrome Exhaust Tip-blackout Bed Rug Tailgate Mat Optima Red Top 35 Weather Tech Side Vent Shades Weather Tech Laser Fit Floor Mats CoverKing Neosupreme Seat Covers Sabellco Tailgate Lock RedLine Quick Hood Lift Elite Subaru Tweeter’s JDMCAR liners Cupeez Scratch Protectors
    Welcome! I vote for “electronically controlled thingamagigy”
