New to forum & having trouble starting
Discussion in 'New Members' started by Zuey, Jan 6, 2012.
  1. Jan 6, 2012 at 8:09 AM
    Zuey
    Zuey [OP] New Member
    Macedon, NY
    08 Tacoma Access Cab, 4x4, V6
    New frame
    Hi everyone; just found your site and was reading some of the posts and decided to join. I have a 2001 Tacoma Xtra Cab 4x4 w/a 2.7L 4 cyl, and 5 speed manual tranny. It's been a good truck and Toyota was nice enough to replace the frame a few years back so most of the underside is new.
    I was having trouble starting it at the beginning of the week. That’s how I found this website. It would start but it acted like it had a flooded carb. I had to floor the pedal to get it to start. It wouldn't idle either but if I keep giving it gas it would stay running. As soon as I let off the gas, it stalled. I tried to replace the fuel filter but ran into trouble reaching the rear fitting so I stopped. But now after getting the truck started and keeping it running for about 5 minutes (till it warmed up), the problem seemed to go away. Now it’s running fine. My concern is I’m driving 6 hours next weekend and don’t want trouble on the road.
    After reading some of the posts, I’m thinking of removing the throttle body and cleaning it along with the IAC valve. It’s never been done since I’ve owned it. Then I should also be able to change the fuel filter. I was also thinking of putting a new set of plugs in it.
    Any ideas or suggestions?
  2. Jan 6, 2012 at 8:30 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    If you've not done the plugs that would be a good start.
    I'm leaning towards your Throttle Position Sensor for the throttle issue.
    While the truck is running tap the Mass Air Flow sensor lighty with the handle of a screwdriver; if the idle changes..the MAF is bad.
    I put a little LUCAS FUEL CLEANER in the tank to lube and keep the injectors from sticking open.
  3. Jan 7, 2012 at 3:53 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    :wave: Welcome to TW :D
  4. Jan 7, 2012 at 3:58 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    welcome bro these guys on here will make you do and be able to fix all kinds of stuff..:wave:
  5. Jan 7, 2012 at 5:39 AM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    Welcome.
    Sounds like you have some ideas already.
    I do not have an idea how to fix it but maybe a thread specific to your issue in the 1 Gen section so more members are able to help. More views that way.
    Good luck with the repair
  6. Jan 7, 2012 at 6:04 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Sounds like you on the right path.
    Welcome to TW
  7. Jan 7, 2012 at 6:09 AM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Good start ^
  8. Jan 9, 2012 at 12:38 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
