New to forum, trannsmission trouble
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaStrong2001, Oct 1, 2010.
  1. Oct 1, 2010 at 10:41 AM
    YotaStrong2001
    YotaStrong2001 [OP] New Member
    Blake
    Rode hard and still rockin'
    Hey guys, I'm new here, looks like a good place for valuable info and help. I have a 2001 3.4L AUTO 4WD Tacoma, got her brand new when I turned 16 and, despite some seriously rough treatment over the years, she's been goin strong ever since. I'm nearly 26 yrs of age now and the taco has 210,000 miles on her. A couple of weeks ago the transmission started slipping and stuttering when downshifting going up a hill. Right when it shifted down it would stutter twice with about a second between stutters. Over the past week and a half it's been more of the same but much worse. I'm broke and can't afford to take it to somebody, so I think I'm about to just change fluid and the filter, but I've never done it. I know the basic process, same as oil and I always do that myself. I just want some feedback from somebody who has done this before. What's the recommended amount of fluid for a drain and refill? Is the filter located just inside the pan after I take it off? Somebody please gimme some info so I don't go and f this up beyond repair.
  2. Oct 1, 2010 at 11:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not much to draining and filling. Pull the pan, and clean out the strainer. Then, Put the pan back on, and fill to the correct level. The pan bolts are torqued to 65 in-lbs so becarfull not to get them too tight. As far as how much fluid goes, it all depends on how much comes out. Your only gonna get a few quarts with a drain and fill, as opposed to all of the fluid with a flush. According to the FSM, Your tranny holds about 10.7 quarts DEXRON III
  3. Oct 1, 2010 at 11:24 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Welcome to the forum and since I haven't messed with an auto tranny before, what he said ^^^
  4. Oct 1, 2010 at 1:55 PM
    YotaStrong2001
    Blake
    10-4, thanks for the input fellas. I'll read a little more and try to figure out where the filter is before I do anything.
  5. Oct 1, 2010 at 4:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No "filter" per se....Its a strainer inside the pan. When you remove the pan, you will see it.
  6. Oct 1, 2010 at 4:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep....unbolt it...drain it out, and clean real good with brake cleaner. reinstall everything, and add tranny fluid. you'll probably add about 5 quarts or so with removing the pan. otherwise, its normally around 3 quarts with justa drain and refill.
  7. Oct 2, 2010 at 1:37 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    If you're going to drop the pan, don't forget about the dipstick tube. It can be tricky to get off & back on sometimes.
    I only get 2 quarts on a drain & fill.
    Sounds like you've never changed the oil? If yes, at this point a complete flush might make things worse. Just a do a few drain & fills & see if it gets any better. First off, pull the dip stick out & see if the oil smells burnt or looks burnt.
