New to lift kits
Discussion in 'Suspension' started by IAMPUREINSANITY, Dec 18, 2017.
  1. Dec 18, 2017 at 9:35 AM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    It's a proven fact. Search on the forums. Diff drops don't do crap for the needle bearing. These stupid needle bearing have been on these Tacomas since 1st gens. They even fail on stock tacoma.
    Good luck OP
  2. Dec 18, 2017 at 9:35 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Because on this site anything but a 3" OME lift is considered garbage
  3. Dec 18, 2017 at 9:36 AM
    Fedup13
    Fedup13 Well-Known Member
    San Diego
    2021 OR DCSB 4x4
    Fixed.
  4. Dec 18, 2017 at 9:41 AM
    doorsidedown
    doorsidedown Well-Known Member
    It will be a stiff ride, but if You change your mind and don’t install can you return/exchange it?
    TacoTRD78 likes this.
  5. Dec 18, 2017 at 9:50 AM
    MuddySquirrel
    MuddySquirrel Well-Known Member
    Will
    Phoenix
    2015 Taco 6-speed Off-Road
    Can you post up the kit you bought?
    Over 3" it should (and if it is this kit: http://www.roughcountry.com/toyota-suspension-lift-kit-746-20.html , it does) have a diff drop. That relieves a lot of the suspension geometry issues quoted above. Downside - you won't get additional ground clearance... but you're not looking to do offroading, so no biggie.
    Most of the dislike for inexpensive kits like RC is that they combine a) lift blocks/spacers and b) inexpensive shocks. Because of a) your truck is essentially on stilts or high heels - it will be more top-heavy and tend not to handle as well in aggressive maneuvers or off-camber. Because of b), running inexpensive shocks and stock rears, these kits tend to have difficulty compensating for the increased roll forces... hence the handling issues at speed.
    If you were looking to wheel the truck, improve handling, or get a smoother ride, one of the other suspension options mentioned above is the better way to go. That's the direction I'm taking my build, but it will be closer to 2.5" of lift when done.
    If you want the truck to look taller, clear bigger rubber, you're not pushing the envelope on handling, and on a budget, a spacer lift is not a bad option. Post up the specific kit you've bought and see if anyone has first hand experience with it doing the same things you will be. I know there are a few folks on here with large (6") drop bracket lifts.
    Welcome to TW
    Tacoaric likes this.
  6. Dec 19, 2017 at 5:51 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so much @oscolivar1 for the recommendation we truly appreciate it! :taco:
    TacoTRD78 and oscolivar1[QUOTED] like this.
