New to lifting. Couple Questions.
Discussion in 'Suspension' started by tr0gd0r, Mar 5, 2009.
  1. Mar 5, 2009 at 11:13 PM
    tr0gd0r
    tr0gd0r [OP] Well-Known Member
    Pullman, WA
    2012 Silver Streak TRD Offroad DCSB V6 4x4
    TRD Catback Exhaust - 265/75/16 BFG KM2s
    Basically I am thinking about doing an AAL in the rear and putting adjustable Bilstein 5100s in front and the replacing the rear shocks with 5100s at the same time as the AAL.
    1. Are the 3 leaf progressive AALs worth the extra money over the single AALs?
    2. Will I need longer brake lines for the lift in the back or front?
    3. Will I have any alignment issues? The front will probably be set on 1.75. Whatever setting will make my truck level.
    4. How about driveline vibrations? Do they occur with the 1.5" lift the AAL adds?
    Thanks for your responses.
  2. Mar 5, 2009 at 11:40 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    1) dont know
    2) most likely not. I have the AAL and brake lines are fine..
    3) you should do an alignment after any adjustments to the front end i think..
    4) yes tacos rule
    5) seems to vary by truck also. install the kit, if you get vibes, go from there.
  3. Mar 5, 2009 at 11:46 PM
    tr0gd0r
    Pullman, WA
    I know I will need an alignment. But I have heard of people not being able to keep their truck aligned. Or is that only from 3"+ lifts?
  4. Mar 5, 2009 at 11:50 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    u may be fine set at 1.75 (someone chime in if i am incorrect). I think majority of the alignment issues are upwards of 2.5"+, this is where new UCA's come in.
  5. Mar 5, 2009 at 11:59 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    1. I've never actually heard of dual add-a-leafs. Got a link about them?
    2. Do you do any offroading? If yes, I'd recommend longer stainless steal lines. You can drive the truck around without extending them. It's when you go offroad and stretch the suspension is when you gotta worry about them being long enough.
    3. An allignment is recommended after a lift
    4. Vibrations will vary...some people get them and other people don't.
  6. Mar 6, 2009 at 12:09 AM
    tr0gd0r
    Pullman, WA
    Here is a place you can get the 3 Leaf progessive AAL I was talking about. The progressive AAL replaces the overload spring.
  7. Mar 6, 2009 at 12:19 AM
    951TRD
    951TRD Well-Known Member
    Irvine, CA
    08 TRD OffRoad
    Tinted windows, Upgraded door speakers with 10" Kicker CVT Sub, Pioneer AVIC D3, Magnaflow exhaust, Bilstein 5100 set to zero and Camburg 4" spindles
    I recently installed the 5100 Billys and set them at 2.5"... Unlike some of the guys on here the alignment has held up just fine and have not experienced any vibes. Couldnt be happier thus far.
  8. Mar 6, 2009 at 4:36 AM
    muliefever
    muliefever Muliefever
    Tillamook, Oregon
    14' DCSB TRD
    5100's, 887', CB, 265's, FM Deltaflow
    How do you know?? Just a heads up, just because it looks fine, does not mean it is fine. If you lifted the front of your truck 2.5 ", you NEED an alignment!
  9. Mar 6, 2009 at 7:35 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    I have that 3 leaf aal...i also left my overload leaf in the spring pack...it rides nice with the bilstien 5125s and flexes great offroad...
    i have NO complaints about it whatsoever
