New to me 1997 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by alr3111, Jun 10, 2015.
  1. Jun 10, 2015 at 6:44 PM
    alr3111
    alr3111 [OP] Member
    Anthony
    1997 Tacoma 4wd
    image.jpg I just purchased a 1997 Tacoma. It belonged to a family friend who passed away in 2012. It has 147k miles on it and has not been driven much since 2012. I have purchased a full OME package from wheeler and plan on doing the following
    Change/service
    Transmission
    Engine oil
    Flush radiator (new hoses/thermostat)
    Differentials
    Ball joints
    Control arm bushing
    Tie rod ends
    Spark plugs and wires
    Fuel/air filter
    Anything else you would recommend?
  2. Jun 10, 2015 at 6:47 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    A cross hanging from the rear view mirror. Welcome to TW!
  3. Jun 10, 2015 at 10:05 PM
    bawilson21
    bawilson21 Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    First off, did the whole family pass away? How'd that happen?
    I would also replace the pcv valve and grommet since its likely stiff and will crack trying to get it out. Clean throttleboddy and MAF, make sure EGR isnt clogged, check voltage on O2 sensors, get the transfer case aswell when you do the transmission fluid change, Grease your (drive)shaft. I recommend the Redline GL4 stuff. Look into when the timing belt was last replaced. Check brakes, if good, bleed brake and clutch fluid if its a manual. If its an Auto, pull pan and replace filter. Replace a portion (or flush) power steering fluid. Service life is 90K miles but the belts on these trucks can last well into 200K miles before they snap (and if they do, it wont harm anything since the engine is a non-interference one... youll just need a tow). If it hasnt had a belt replacement yet, I would hold off on doing the radiator flush /hoses until you do the timing belt since you'll need to drain the radiator most likely. Whenever you do the timing belt, replace all the other belts.
  4. Jun 10, 2015 at 10:25 PM
    Dmesser92
    Dmesser92 Well-Known Member
    Dylan
    Easley, South Carolina
    2023 Tacoma SR AC V6 4x4 | 1991 Toyota Pickup 4x4 DLX V6
    Congrats on the new ride, I've always loved the older first gen front ends!
  5. Jun 11, 2015 at 5:25 AM
    alr3111
    alr3111 [OP] Member
    Anthony
    1997 Tacoma 4wd
    Left out significant word in the original post. It was a family friend who passed, not a family.
    Thanks for the additional items
  6. Jun 11, 2015 at 9:27 AM
    PedroH
    PedroH Well-Known Member
    First time i see a Tacoma with the same side step as mine. Nice ride.
