New to me: 2014 Tacoma D-4D
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaD4D, Dec 29, 2021.
  1. Dec 29, 2021 at 8:28 PM
    TacomaD4D
    TacomaD4D [OP] Well-Known Member
    Central TX
    2014 Tacoma TRD D-4D
    DieselToys engine swap Lots more to come….
    Finally got back into a Tacoma! Just purchased this 2014 Tacoma D-4D with 36k miles. Found it locally on Facebook marketplace. Apparently DieselToys did this swap a few years back. Truck went into limp mode twice on the drive home but I am 90% sure it’s something simple. Restarting the engine cured the limp. I will keep this post updated after I get into a little more.
  2. Dec 30, 2021 at 1:01 AM
    TacoTuesday1
    FL
    I wonder how much it was if you don't mind me asking
    got any pics of the engine bay?
    this gives me hope that the swap can be done
    so far truck looks clean almost like the swap is working well
  3. Dec 30, 2021 at 5:08 AM
    TacomaD4D
    Central TX
  4. Dec 30, 2021 at 6:08 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
  5. Dec 30, 2021 at 8:40 AM
    Sean42
    Sean42 Well-Known Member
    Did the seller disclose the issue? Thing is so sweet and crazy low mileage too.
  6. Dec 30, 2021 at 9:48 AM
    vettaco
    vettaco Well-Known Member
    Vince
    09 AC PreRunner
    Wow, very cool! A hood scoop would be nice to feed some cool air over that intercooler
    Junkhead and TacomaD4D[OP] like this.
  7. Dec 30, 2021 at 12:10 PM
    TacomaD4D
    Central TX
    Found it at a used car dealership…no disclosures and was sold as is. I was told the previous owner was military and had orders to move to Alaska.
  8. Dec 30, 2021 at 1:20 PM
    fresyota
    fresyota Well-Known Member
    2013 Tacoma Base Access Cab 4x4 2.7 A/T
    1KD-FTV 5SPD AUTO 4x4
    • A750 5SPD AUTO TRANSMISSION
    • 188hp 310 lb/ft Torque @ 2,200rpm
    • 1KD-FTV 3.0 COMMON RAIL TURBO DIESEL
    • VNT TURBOCHARGER
    $28,500COMPONENT COST $17,500 + INSTALLATION $11,000INQUIRE NOW
    1KD-FTV 6SPD MANUAL 4x4
    • RA61 6SPD MANUAL TRANSMISSION
    • VNT TURBOCHARGER
    And you only had to pay 33k? Good luck my friend.
    TRDSport10, Junkhead and 2015WhiteOR like this.
  9. Dec 30, 2021 at 1:30 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Seems like a great deal or a lemon. If you get limp mode problem figured out cheap and easy it's a great deal.
    Good luck and keep us posted.
  10. Dec 30, 2021 at 1:32 PM
    AllTacosFloat
    Boston ish
    Less, he paid 26k
    Squirt likes this.
  11. Dec 30, 2021 at 1:35 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    Oh thats sweet!
  12. Dec 30, 2021 at 1:35 PM
    Clearwater Bill
    Billy
    Largo Florida
    And diesels wont run there, right?
    I've heard the 'military' story a bazillion times regarding vehicles over the years.
    I hope yours is true and its problems are easy to cure
  13. Dec 30, 2021 at 1:42 PM
    fresyota
    Oh dear...:pray:
  14. Dec 30, 2021 at 2:49 PM
    TacoTuesday1
    FL
    Holy shit
  15. Dec 30, 2021 at 4:00 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Alright. Once it is running right, the world needs to know the gas mileage, and can it fit 35's?
    nd4spdbh likes this.
  16. Dec 30, 2021 at 4:03 PM
    Clearwater Bill
    Billy
    Largo Florida
    You mean MPGs, right? Because it's technically not 'gas' mileage, it's 'diesel' mileage. :D:D
    And at the cost differential I see at the pump on diesel it would have to be a hefty increase to reach a break even point........
    Torspd[QUOTED] likes this.
  17. Dec 30, 2021 at 4:22 PM
    2015WhiteOR
    Gainesville TX
    Seems some of you are unaware of these trucks? There's a handful of good videos on youtube:
    Torspd likes this.
  18. Dec 30, 2021 at 6:15 PM
    fresyota
    If it's right it should get somewhere close to 25-30mpg with more torque than a V6
    TacomaD4D[OP] likes this.
  19. Dec 30, 2021 at 6:22 PM
    fresyota
    But I am highly skeptical because it's virtually impossible to find a regular gas powered 14 trd sport with 36k miles on it for 26k let alone one with a 28k diesel upgrade.
  20. Dec 30, 2021 at 6:49 PM
    TacomaD4D
    Central TX
    Hell you and me both…seems to be in great shape though. Motor sounded good and drove like factory. Worth a shot!
    Dan 77 likes this.
